self install crazy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-23-2007, 07:18 AM - Thread Starter
vikes88's Avatar
Im looking at upgrading my ford cobra's sound system mainly for connectivity reasons (Id like to get a deck that plays mp3s and easily connects to an ipod - something like an Alpine CDA-9883).
As long as Im doing it I figured I might as well add like a 10" sub to the trunk.
I always shop at Ultimate Electronics but I cant help feeling that I wont be getting a good deal buying all of the stuff there.
I've never done any car audio installs before and Im wondering how much of a pain this would be to do myself. And would it be worth it?
Running the cables to the trunk?
vikes88 is offline
post #2 of 4 Old 04-23-2007, 04:01 PM
Greg_R's Avatar
Well, that depend on how intricate you want to get. A head unit install is pretty straightforward (especially with the cable adaptor kits sold by Crutchfield and others). If you start adding sound deadening material and routing your cables through the frame then things get a bit more advanced! I added 2+ layers of dampener and 1 layer of absorption material on the entire interior of my car. My buddy and I spent from 8 a.m. to 2 a.m. and got about 1/2 of it done. It took another 2 FULL days working by myself to add the rest of the material and hook up the electronics (simple component speakers + sub, 2 amps, cap, XM, headunit). A similar install at a local custom shop would run thousands of dollars.
If you are techno-savy I'd say you could install all the electronics in under a day (assuming no custom kick pod building, etc.). If you start adding dampening and absorption material or any sort of custom enclosure then your time really starts to add up...
Greg_R is offline
post #3 of 4 Old 04-23-2007, 10:38 PM
flent's Avatar
what year cobra?? I ask this because they all have factory amps, some easily bypassed while others are more of a pain.
flent is offline
post #4 of 4 Old 04-24-2007, 08:08 AM - Thread Starter
vikes88's Avatar
Its a 2003
vikes88 is offline
Reply Car Audio, Video, and Nav
