Would like to integrate IPOD into factory Camry Nav/Radio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-07-2007, 04:29 PM - Thread Starter
MakiC's Avatar
I have a Camry Hybrid with factory Nav/radio. I have a 5G ipod. I would like to get a hardwired adapter to access the music on the ipod through the factory radio. I have seen several out there, but can't tell what interfaces they have (and what ease of use). I would prefer being able to use the touch screen to navigate the songs, etc.
Video playback would be nice, but I don't think that it exists.
Anyone have such a set-up that they are happy with?
MakiC is offline
post #2 of 8 Old 09-11-2007, 01:40 PM - Thread Starter
MakiC's Avatar
Anyone have any suggestions?
MakiC is offline
post #3 of 8 Old 09-24-2007, 01:40 PM
cusm's Avatar
This might work for you.
http://www.vaistech.com/sli.html
cusm is offline
post #4 of 8 Old 10-06-2007, 01:39 PM
Distorted's Avatar
Quoted: 433 Post(s)
Liked: 345
I am having one of these installed in my Lexus next week. I'll report on the result later.
http://www.carsound.com/artman2/publ..._CONTROL.shtml
"Without music, life would be a mistake." - Friedrich Nietzsche
Distorted is offline
post #5 of 8 Old 10-16-2007, 01:48 PM - Thread Starter
MakiC's Avatar
How is that working for you?
MakiC is offline
post #6 of 8 Old 11-02-2007, 11:44 AM
Ashcan's Avatar
I installed car audio for about 6 years or so. I have used peripheral equipment all the time. They never failed me before.
I would suggest this piece for your I-Pod
"http://www.peripheralelectronics.com/prodDetail.asp?strProductID=403&strSearch="
Just locate a dealer or online retailer and you should be good to go.
Drop the Quote marks Im a first time poster and it wouldn't let me post a live link
Ashcan is offline
post #7 of 8 Old 11-07-2007, 09:53 PM
Brandonw27858's Avatar
I can vouch for Peripheral. I bought one for my 2004 Jeep Wrangler and it works great. The only thing I wish it would do is display the song info on my radio display, but really I dont need that. I got mine off Ebay. Good luck!
Brandonw27858 is offline
post #8 of 8 Old 11-12-2007, 05:31 PM
troy_audi0's Avatar
Checkout this part
http://www.usaspec.com/ipod.html
Great item..
They run in the $220 area..
Troy_Audi0
Store Manager Of Axxis Audio
Custom Fiberglass & System Design
troy_audi0 is offline
Reply Car Audio, Video, and Nav
