My First HD Camcorder - AVS Forum
post #1 of 2 Old 08-21-2008, 09:09 PM - Thread Starter
orbs's Avatar
Hi. I'm looking for a camcorder with the following:
1) High definition video recording (720p or greater)
2) Image stabalization (electric/digital is fine but optical is preferred)
3) HDD-based storage
I want to spend $550 US or less. I'm also not looking for something poorly built that will freeze up and die after a few uses.
Are there any camcorders that meet those requirements?
Jared
Whatever tears at us, whatever holds us down, and if nothing can be done, we'll make the best of what's around. - DMB
orbs is offline
post #2 of 2 Old 08-22-2008, 07:40 AM
ericjut's Avatar
No new camcorder like this is available at the moment below $550.
The Canon HG10 ($615) might be the closest to what you're looking for, but I would highly recommmend paying a little more and getting its successor, the HG20, that is about to come out to get all the latest improvements in that department (I would also wait a little for the price to settle).
The cheapest Sony in that class is the SR10, and is available at $695.
You could also look at the refurbished/used market to get to that pricepoint, but those camcorders are currently huge leaps in PQ and features on each generation, so you would be compromising PQ/features for price.
I'm sure more than one here will question your requirement to get a HDD and gear you towards a flash-based camcorder. If that would be an option for you, you can look at the cheapest Panasonic AVCHD or the Canon HF100 that you can find available in the low $600s. Note that you'll also have to buy a flash card, but are getting pretty cheap right now.
ericjut is offline
Reply Camcorders
User Tag List
