Canon Vixia HF11 (Owners Thread) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 335 Old 09-16-2008, 06:36 AM - Thread Starter
NJ3118's Avatar
So whos got it? I just ordered mine should be here by Friday.
I was on the fence FOREVER about choosing between the HF10 and the HF11. Dont get me wrong I diddnt choose SOLEY because of the 24Mbps, but rather the sense of that in a year or less there will be mutliple 24Mbps cameras on the market and this is a decent investment for me that I wont purchase another for well over 2-3 years.
I for sure cant tell the difference in bitrate, but feel comfortable knowing I never have to wonder what it "would" look like if I bought the HF11. Yea, bite the marketing bullet.
OK, so does anyone else own this camera yet? Love to hear some early reports. Read some reviews but vimeo and youtube have NOTHING on some test footage.
Read some good reviews but they all say the same "No Noticeable difference in the bitrate jump" and Small Cosmetic differences as well as 16GB extra memory is the only changes. VW/PQ remains the same....
I have a fever and the only cure is more Blu-Ray....
NJ3118 is offline
post #2 of 335 Old 09-16-2008, 09:47 AM
citykid1's Avatar
So far my HF11 has worked flawlessly, it's a fantastic camera. I haven't scrutinized the 24mbps vs 17mbps bit rate differences since I've only had the camera for about a week, but like yourself I opted for the HF11 over the HF10 since I would have been wondering how much better the increased bit rate would have looked had I purchased the HF10. The Canon marketing works...
Now if the AVCHD editing software will catch up to the capabilities of this camera we'll been in good shape! (as I mentioned in my HF10/HF100 forum post regarding using Vegas 8.0c and being unable to output rendered video at 24mbps). Again, I hope I am just missing something.
I have tried the latest demo versions of PowerDirector and also VideoStudio X2 but still was unable to produce video output with the same quality as the HF11's original clips. VideoStudio was painfully slow and it's media player struggled to playback the AVCHD video. (FYI I'm running an HP - Core 2 Quad CPU with 6Gb of ram and separate SATA drives for input and output video data).
Unfortunately, Canon's simple Image Mixer software seems to work the best for editing and playback with this camera. When I perform simple edits and write the rendered files back to the camera for playback they look as good as the original (which is the way it should look!).
The HF11's direct HDMI output to a 65" Sharp Aquos TV looks fantastic.
citykid1 is offline
post #3 of 335 Old 09-16-2008, 03:39 PM - Thread Starter
NJ3118's Avatar
Yes I too am a sucker for "technology marketing" the damn tech sells itself though. Glad to hear your happy (except for the Vegas issue) BUT I should have mine in hand tomorrow. I need to pickup a Mini HDMI in the meantime (monoprice here I come)
Im using Final Cut on a Macbook Pro...Well see what happens when I start to funnel in the 24Mbps clips...
PS Have you checked the vimeo.com HF10 Channel yet? Some amazing clips produced from these cameras. My first HD camera so I'm really excited. BTW do you know if the PS3 will play these clips?
NJ3118 is offline
post #4 of 335 Old 09-16-2008, 05:11 PM - Thread Starter
NJ3118's Avatar
?? While looking at the Specs I noticed that the HDMI out only outputs at max 1080i??? IS this true not 1080p?
"HDMI Terminal
Type C 480i / 480p / 1080i Format Supported"
NJ3118 is offline
post #5 of 335 Old 09-16-2008, 08:34 PM
citykid1's Avatar
The mini-HDMI adapters were hard to find in the Chicago area, probably too new. Got mine as well from Monoprice. They really save you a bundle on cables compared to the local retailers.
Would be interested to know if Final Cut can output 24mbps AVCHD files. I'm sure all of the editing software firms will eventually support that format and bitrate soon.
As far as 1080i output, it typically gets converted to 30 fps progressive anyway in LCD TVs so I'm not too concerned about the interlaced output. Not sure if the AVCHD standard includes 1080p 60fps capability. Will have to investigate that issue.
citykid1 is offline
post #6 of 335 Old 09-16-2008, 09:55 PM
Paulo Teixeira's Avatar
Quoted: 78 Post(s)
Liked: 44
I don't have the HF11 but I can answer that one. The PS3 is compatible with every AVCHD camcorder.
Paulo Teixeira is offline
post #7 of 335 Old 09-17-2008, 06:51 AM - Thread Starter
NJ3118's Avatar
cool thanks!
NJ3118 is offline
post #8 of 335 Old 09-17-2008, 01:53 PM - Thread Starter
NJ3118's Avatar
NJ3118 is offline
post #9 of 335 Old 09-18-2008, 07:09 PM
agile's Avatar
Yes it will play flawlessly on the PS3. I have the 80gb version with card reader. I was able to pull the card out of the HF11 and play the files directly from the SD card. You just navigate to the Stream folder. Also, I burned the AVCHD files to a DVD and was able to play on a friend's PS3. I love the camera and really love the versatility of the PS3.
Onkyo TX-NR3007
Klipsch THX Ultra2 Home Theater System
Emo XPA-3
JVC DLS-RS20U
Carada 110" Criterion Bright White
LG BD590
XBOX 360
agile is online now
post #10 of 335 Old 09-18-2008, 10:20 PM - Thread Starter
NJ3118's Avatar
Hey thanks! Yes i too had no problem playing the files on the PS3. The first time I just plugged the camera through USB to the PS3 and it worked fine. THe only thing is that you need to shutdown the PS3 before it will allow you to power down the Camera.
Anyways, love the camera. Starting to fool around with my DOF adapter. I am going to try and create an HF11 channel on Vimeo in a week or two once I get some nice clips together. BTW I was playing clips at 23-24Mbps so the HF11 truly does record at that bitrate....
NJ3118 is offline
post #11 of 335 Old 09-19-2008, 02:29 AM
img eL's Avatar
How is native editing with 24bit files?
img eL is offline
post #12 of 335 Old 09-19-2008, 07:07 AM - Thread Starter
NJ3118's Avatar
I only used imovie for a short test edit and then FCE....(Macbook 4GB Ram)
1.) With iMovie : Importing clips took about 1.5-2x the clip length
2.) With FCE its was about a 1:1 ratio Maybe a little shorter....
NOW rendering on iMovie was a joke...about 2X clip length (but this is the same with 17Mbps clips)
Have yet to render a clip with FCE will try tonight...
NJ3118 is offline
post #13 of 335 Old 09-19-2008, 04:06 PM
osv
osv's Avatar
i got the hf11 because of the 24mbs bitrate, the footage i shoot is usually fast motion stuff.
here is a vixia hf11 review that i put together, it has sample footage and some pics... what i want to know is, are these white dots dropouts of some sort?
Canon Vixia HF11 Review
osv is offline
post #14 of 335 Old 09-19-2008, 10:27 PM - Thread Starter
NJ3118's Avatar
Hey GREAT Mini Review...
1 comment. The HF11 is the "only camera" to support 24Mbps at the moment for AVCHD format...
Other than that the second page was not working in your review...
I havent noticed those white specs on my camera yet and I have shot about an hours worth of footage similar to yours... What recording modes are you using?
NJ3118 is offline
post #15 of 335 Old 09-20-2008, 09:43 AM
osv
osv's Avatar
thanks, that review was a lot of work, i haven't finished the second page yet... i think you are right about the hf11 being the only camera on the market that shoots 24Mbps.
i was shooting in 24Mbps mode, and i saw the white specks in only a couple of clips... i shot some more last nite, we'll see if any of that footage is compromised.
osv is offline
post #16 of 335 Old 09-21-2008, 07:11 PM - Thread Starter
NJ3118's Avatar
Yes, we all def appreciate your contribution! Thanks again.
Let me know when the rest of the review is up and if you would like to share some clips...
NJ3118 is offline
post #17 of 335 Old 09-22-2008, 04:00 PM
citykid1's Avatar
I have shot about 5 hours of video with the HF11 and have not noticed any white specs as seen in your video frames. One thought is some type of lens reflection being captured by the sensor. If it was dust on the sensor it would appear as dark specs. If it was a sensor defect it would appear in every frame. Unless it is some type of really unusual compression artifact although it does not look very digital in nature. (i.e. the shapes of the specks would be likely show more symmetry).
citykid1 is offline
post #18 of 335 Old 09-22-2008, 06:06 PM
osv
osv's Avatar
i was thinking reflection as well... or perhaps bad memory cells? i'm still evaluating the new footage, but i haven't seen anything bad yet... i added on to what was already shot, so i wasn't accessing the same area of memory as i was with the bad clips.
osv is offline
post #19 of 335 Old 09-25-2008, 04:47 AM
tat2jr1's Avatar
I just got mine today, and while the footage looks awesome I'm having some problems with my old AVCHD workflow that I was using.
I just got the new Canon HF11. I want to shoot in PF30 (30 frames progressive mode) at the 24mbps setting. I am using Video Studio 11.5+.
Video Studio is importing the files that I've recorded in 30p/24Mbps just fine EXCEPT that they are saying it's upper field first. It's not. I need it to import them as Frame Based, so I can grab stills from the video, and work with it in progressive from start to finish (I only output to DV or lower, so AVCHD or HD output in progressive is NOT needed). Input IS needed though. The stills look awful when grabbed with Video Studio 11.5+.
I think the problem is that canon has wrapped their 30p in some kind of 60i system or something. Not sure. And I KNOW the problem with Video Studio is that it's automatically decided that my file is upper field first, because I downloaded the trial version of Vegas Movie Studio Platinum 9.0, and with that program it lets you change the field order to frame based. I can grab perfect stills... and work with it in progressive then. I need the same in Video Studio. Does anyone know a way to force VS to import a different field order, OR have a freeware program that will change the header info on a AVCHD file to make it say it's frame based or progressive?
Using Video Studio 11.5+ I know you can change field order when you export the files into different formats, but I need to change the field order on the import of these files.
I hope someone has an answer for me! I don't want to change from Corel as I've gotten use to it, or return this camera. Thanks in advance.
tat2jr1 is offline
post #20 of 335 Old 09-25-2008, 04:47 AM
tat2jr1's Avatar
I couldn't post a sample video until I had 3 posts.
tat2jr1 is offline
post #21 of 335 Old 09-25-2008, 04:49 AM
tat2jr1's Avatar
Sorry guys.... wanted to post a sample video that was shot in the 30p to see if someone can help me. (3rd post!)
tat2jr1 is offline
post #22 of 335 Old 09-25-2008, 04:50 AM
tat2jr1's Avatar
I've uploaded a 1 minute clip shot in the 30p/24mbps mode from the new canon HF11. It's 176 MB.
http://rapidshare.com/files/14817971...1-30p.zip.html
If anyone could help me figure out how to import this into Video Studio 11.5+ correctly that would be awesome.
tat2jr1 is offline
post #23 of 335 Old 09-25-2008, 06:34 AM
tat2jr1's Avatar
You know guys..... I may be thinking about this wrong. I've been outputting that video file to different formats (DV, WMV 720pHD, DVD) all as progressive (field-based), and they're all looking really good. It makes sense when you think about how this interlacing is done (progressive segmented frame). This explains it more.
http://www.elurauser.com/articles/ca...sive_modes.jsp
Now, I WON'T be able to grab stills in VS11.5+ because the program thinks this is normally interlaced video,and they look awful, but I can frameserve the files in to virtualdubmod and grab stills from there.
Do you guys think I'm on the right track with my thinking on the progressive output for videos on this file?
tat2jr1 is offline
post #24 of 335 Old 09-27-2008, 07:52 AM - Thread Starter
NJ3118's Avatar
Hi, wish I could help, but I'm do not have much experience with Video Studio.....
I'm a FCP guy....
I can do a lil research for ya and see what I can stir up...
NJ3118 is offline
post #25 of 335 Old 09-27-2008, 09:23 PM
osv
osv's Avatar
i think that the dv format is strictly field-based, it does not record progressive frames(?)
if the stills you are capturing have that interlaced problem, all you have to do is to bring them into a photo editing program and deinterlace them there... the frame grabs in the link i posted were all deinterlaced in photoshop, the originals looked really bad.
there is some blur on the car, because i was shooting at 1/60th, and zooming really fast... the shot of the scoreboard did not have any of that.
osv is offline
post #26 of 335 Old 10-13-2008, 09:15 PM
ptr727's Avatar
I got my new HF11 last Friday, been playing with it the weekend.
I connected the camera using USB to my Vista x64 system, I set the camera to video playback, I power on.
I get a message on the screen that I must connect the power adapter.
The manual states you may need to connect the power adapter, I wonder what "may" means.
I connect power, and two removable drives show up on the PC, one for internal storage, one for the SD card.
On further experimentation I found that if I set the samera to picture playback, then I do not need external power, but then the video folder does not show up in Windows.
In video playback mode both the video and picture folder is visible.
I copy the internal drive contents to my machine, about 1.5GB of MTS files, using Windows Explorer, the transfer took more than 10 minutes, very slow.
I tried again, this time using robocopy, and the copy was a bit faster, but still very slow 1.553GB, 9 minutes 19 seconds, at 2.98MB/s or 23.84Mb/s.
That is a bit slower than the 24mb/s recording speed!
I am very dissapointed with the data ransfer rate between the camera and my PC.
Can any other owners comment on data transfer speeds?
P.
ptr727 is offline
post #27 of 335 Old 10-14-2008, 09:48 AM
Outkasted's Avatar
I was thinking about getting this camcorder (hf10) for a video project I will be working on. Will I be able to make a movie with this (35 mins or so) and burn it on DVD? Do I need blu ray burning capabilities to use this?
Outkasted is offline
post #28 of 335 Old 10-22-2008, 12:59 PM
wbloodchildw's Avatar
I am looking around for a camcorder to get my wife for Christmas. I am considereing the HF11, but my wife just brought up a concern. I have a ps3 and a TV with HDMI so I will have no problems viewing video at home, but when we go to my parents house they do not have a TV with HDMI and she wanted to know if there is a way to directly play videos from the HF11 on an older TV without HDMI conncetions. Thank you for any information.
wbloodchildw is offline
post #29 of 335 Old 10-22-2008, 02:42 PM
spree43's Avatar
Yes, with the AV out port and the included cable. It just won't look as nice.
spree43 is offline
post #30 of 335 Old 10-22-2008, 05:04 PM
osv
osv's Avatar
i noticed the same thing.
i'm wondering if the transfer speed from an sd card to the computer will be quicker... maybe that should be the recording medium, instead of the internal camcorder memory?
osv is offline
Reply Camcorders
