Camcorder recommendation for grandma - AVS Forum
post #1 of 2 Old 12-18-2008, 07:10 AM - Thread Starter
eddiebrock's Avatar
I want to get her a new camcorder, but the problem is almost all the ones I'm familiar with require you to transfer to a PC She doesn't have a high def TV and doesn't own or ever plan to buy a PC, so I guess the best bet would be a DVD based camcorder?
Does anyone have suggestions for one that's easy to operate for an older person and cost < $300?
eddiebrock is offline
post #2 of 2 Old 12-18-2008, 07:31 AM
NJ3118's Avatar
http://www.camcorderinfo.com/d/Revie...vel_c=DVD.htm#
check out that link it has all you need to know....
I have a fever and the only cure is more Blu-Ray....
NJ3118 is offline
Reply Camcorders
User Tag List
