Difference between *.mts and *.m2ts files - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-18-2008, 02:23 PM - Thread Starter
Zvonimir's Avatar
Hello to all.
Some HD camcorders (like my Canon HF 100) records movie as *.mts and the other as *.m2ts files.
What is the difference between this two files?
Zvonimir is offline
post #2 of 3 Old 12-18-2008, 03:27 PM
kalak's Avatar
They are the same. You can rename one to the other.
*.MTS conforms to the DOS 8.3 file name in those device which requires it.
kalak is offline
post #3 of 3 Old 12-19-2008, 01:21 PM
Rich127's Avatar
Originally m2ts stood for "mpeg-2 transport stream" which supports mpeg-4 (AVC) streams. But those m2ts mpeg-2 transport streams are different from the mts/m2ts AVCHD container. When you are talking about AVCHD, there is no difference between the mts and m2ts files except other than the filename.
I guarantee the above information for 59 minutes. Then someone will probably figure out how to change it...
Rich
Rich127 is offline
Reply Camcorders
