Panasonic HDC-SD1 battery - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-29-2008, 10:45 PM - Thread Starter
djqwik's Avatar
I hope someone can help... I just purchased off of EBAY one of those Generic batteries that say "for vw-vbg130" and are supposed to be for the SD1. The voltage is 7,3 instead of 7.3 and is 1400MAH instead of 1350mah. WHen I put the battery in the camera, the camera will NOT turn on. Does anyone know why? I read (after oprdering) that the SD1 batteries are chipped and ONLY panasonic batteries will work? is this true? If not, how can I get this battery working. THe battery came with 4 little "accessory" pieces and it says to put on on the DC connector. on the SD1 the DC connector is on the side of the camera and not near the battery area since the battery goes inside.
Any help would be appreciated...
djqwik is offline
Reply Camcorders
