The "Official" Canon HFS10 / HFS100 Owner's Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 476 Old 06-21-2010, 06:49 AM
rocknrollchef's Avatar
(one more) How does your fancy rig translate towards run & gun/shoulder mounted shooting? Or do you have other gear for that? I would love any/all input on the best accessories for the handheld shots.
thanks,
m
rocknrollchef is offline
post #452 of 476 Old 06-22-2010, 04:30 AM
Aloha All:
Just got my VIXIA a few weeks ago from B & H Photo - I think this camera is now discontinued, so I got it for $700.00.
QUESTION: Even though I love the ability to control the audio level, I've noticed some pretty pronounced (annoying) compression/limiting from my lavalier mic on the footage - is there any way to turn it off? FYI, I've been shooting in 24p Cine mode, if that makes a difference.
OVERVIEW. More, as an "old school" shooter, I would say the difference here is how much of the controls are internal/digital, vs. knobs & buttons. Quite a learning curve, but it's looking like it will be worth it when it comes to HD quality footage.
Finally, I'm wondering where the best place is to get answers to some of the tricky stuff and/or "inside tricks" for this camera?
thanks,
m
post #453 of 476 Old 07-30-2010, 10:07 AM
tenks777's Avatar
Originally Posted by redshinobi View Post
This might have been covered somewhere but i started to get a headache looking for it
How do you encode it videos and not get this choppy result:
http://www.youtube.com/watch?v=TNiunblbLnw
i have a canon hf s100. i use adobe premier. i shoot in MXP @ 24p and i set the premier project at 1080 24p. i use the export encoder and this is what i get
When you find this answer, you and I will both be suprised. Canon's "24p" option is a ****ing crap lie and it has wasted probably 50+ hours of my time for nothing.
tenks777 is offline
post #454 of 476 Old 07-30-2010, 10:12 AM
tenks777's Avatar
HAS ANYONE FOUND OUT HOW TO EDIT the footage shot with this camera's "24p" setting??
I've looked+tried for what seems like a year, and still haven't found a solution. The entire year I've owned this camera, i have been trying to figure out how to edit 24p footage from the HFS10. It doesn't go into any Adobe Premier CS5 preset timeline, even the canon ones.
tenks777 is offline
post #455 of 476 Old 07-30-2010, 02:39 PM
eiker_ir's Avatar
anyone knows a good lens hood that fits the WD-H58 wide lens adapter?
eiker_ir is offline
post #456 of 476 Old 08-05-2010, 11:29 AM
chops411's Avatar
eugenia.gnomefiles.org/2008/01/04/canon-avchd-24p-pulldown-removal/
or
cineform.com
chops411 is offline
post #457 of 476 Old 08-05-2010, 02:11 PM
Ungermann's Avatar
Quoted: 650 Post(s)
Liked: 94
It is not exactly what you think it is, but I agree that Canon should have implemented native 24p on their AVCHD models right from the start.
Ungermann is offline
post #458 of 476 Old 08-08-2010, 10:28 PM
Shinnbone's Avatar
All
I have an odd issue with the auto closing lens on my hfs100. All of a sudden only one half (the same half) will open or close. Is this mechanism easily broken and/or fixed?
Any thought would be helpful before I send it in for service.
Thx
John
P.s. Apologize that I couldn't search thoroughly for previous responses but am on vacation and only have iPhone kludgy access. Thx.
Shinnbone is offline
post #459 of 476 Old 09-03-2010, 08:29 PM
Bondtana's Avatar
Can anyone recommend a good bang for your buck macro lense for the HFS100?
Bondtana is offline
post #460 of 476 Old 09-16-2010, 03:43 PM
mark-mvs's Avatar
Is it my imagination or does the picture stutter a lot in this mode? I know everyone tells me that it looks more like film but when I've experimented with it, the display on my camera is very very jerky. Especially if both I and the subject are moving. If the camera is on a tripod and the subject is not moving or not moving much, it looks ok, but well.... I don't get it... it doesn't look so good to me in this mode (with or without cinema mode enabled.)
thoughts... maybe I'm doing something wrong...
thanks
Mark
mark-mvs is offline
post #461 of 476 Old 09-16-2010, 04:09 PM
Ungermann's Avatar
Quoted: 650 Post(s)
Liked: 94
If you don't know how to use it then do not use it. This frame rate is for those with "indie film" aspirations. Forget about it. Use 60i for converting to DVDs, or 30p for uploading to YouTube.
post #462 of 476 Old 09-17-2010, 09:54 AM
ktoolsie's Avatar
Quoted: 27 Post(s)
I agree. Instead use 30p in Shutter speed priority mode, with the shutter speed set to 1/30 sec.
ktoolsie is offline
post #463 of 476 Old 09-26-2010, 09:35 PM
gomes_la's Avatar
This may not be the right palce for it bt someone a while back had asked about coverting the mts files. So I'm just sharing some of my experiences over the last 7 months since I've had this camera. I had been looking for something to batch encode a lot of videos at once of my son growing up. For ages the only thing I could find was Sony Vegas Pro that could handle the mts and output to something I could display on the web. Unfortunately I didn't really have the money for it so looked for other things. But as I'm a big fan of open source and I found a good free encoder you can use called ffmpeg. It's all command line and you have to play with it a bit to get the results you want but I am able to encode from and to to a bunch of different formats for the web like flash and quicktime mov, and the newer webm format. This has been useful for me because I've been able to just deal with videos from my canon hsf100, iphone and flip in one place. I'm not bashing Sony Vegas Pro it seems like a fantastic tool for the pro, but if you're someone like me just looking to share some videos on the web with your family then this does the trick. If you're decent at some programming language like java you can write a wrapper around the command line executable to generate different formats. Just search for ffmpeg and google should bring it up as the first result.
Just thought I'd share my experience this may not be for everyone as I'm just experimenting. Here are the command lines I use look at he extension for output type:
ffmpeg.exe -i c:\ emp2\\input\\20100404123623.mts -s 640x480 -y -keyint_min 0 -g 250 -skip_threshold 0 -qmin 1 -qmax 51 -vcodec libvpx -b 614400 -acodec libvorbis c:\ emp2\\vids\\20100404123623.webm
ffmpeg.exe -i c:\ emp2\\input\\20100404123623.mts -qscale 4.0 -s 640x480 -y -ar 22050 -ab 96k -f flv c:\ emp2\\vids\\20100404123623.flv
And for a thumbnail
ffmpeg.exe -i c:\ emp2\\input\\20100404123623.mts -s 320x240 -y -ss 1 -sameq -vframes 1 -an -f mjpeg c:\ emp2\\vids\\20100404123623.jpg
gomes_la is offline
post #464 of 476 Old 10-10-2010, 03:37 PM
ddash's Avatar
Hey Everybody,
I am new here,but this thread really helped me make my decision on what camcorder to get. It was between the Canon HF200 and the Canon HF S100. After reading hundreds of reviews and comments,I finally bought a refurbished Canon HF S100 today. It just seemed to be much better than the HF200 and the price difference was only $150. Canon told me that much of their refurbished camcorders were unused overstock items that were returned from stores. I will see when I get mines,but I got it for a great price.
Canon has a big sale on their website until October 23. I also found a 5% off coupon.
Here is the 5% off code 5VIDRFB
Just copy and paste it in the promotional box when you checkout.
ddash
ddash is offline
post #465 of 476 Old 10-14-2010, 05:42 PM
ddash's Avatar
I received my camcorder today and man does it looks brand new. I ordered my 8gb sdhc card,but it hasnt arrived yet. It wont be here until monday which sucks. I think i might go buy 1 tomorrow to shoot some test footage.
ddash is offline
post #466 of 476 Old 10-20-2010, 07:49 AM
chops411's Avatar
Congrats. Its a great camcorder.
chops411 is offline
post #467 of 476 Old 10-22-2010, 06:04 AM
ddash's Avatar
Thanks chops.
I did a couple test shots around the house and boy does it look great. I only paid $474 for it and it looked perfectly brand new.I bought a 16gb card,8 gb card,BP827 battery,tripod and mini hdmi cable for only $75 extra.
I am very happy with my purchase. The only thing I didnt like was that imovie didnt open up the mts files,which I knew before hand. I found a great little free program called handbrake that converts the mts files nicely.
ddash is offline
post #468 of 476 Old 10-25-2010, 08:23 AM
AbMagFab's Avatar
Does anyone know what the best consumer/prosumer software is for video editing video that comes off this, and similar, camcorders?
My main requirement is no transcoding, 30p 60i or 24p, so that all work is native. So if I want to simply chain a couple clips together, it should be nearly instant (time code adjustments aside).
Ideally Mac OSX, but Windows 7 is fine as well.
I've searched around (Vegas, Final Cut), but theres's nothing in the software descriptions that talk about native editing or no transcoding of certain formats.
Thanks in advance for any advice!
TiVo is on it's way out - stream everything!
AbMagFab is offline
post #469 of 476 Old 10-26-2010, 09:39 AM
chops411's Avatar
I used Sony Vegas Pro.
chops411 is offline
post #470 of 476 Old 01-12-2011, 08:10 AM
TheDarkMike's Avatar
Hey guys!
I'm new to this forum, so HI!
I need your expert knowledge about settings on my HF S100:
I'm into filming rally car races and there's one race coming up in February. It's winter (lots of snow) and lots of speeding cars going by. Any suggestions about getting the best images for that kind of action?
Thanks for you help!
The Dark Mike
TheDarkMike is offline
post #471 of 476 Old 01-12-2011, 02:06 PM
chops411's Avatar
Originally Posted by TheDarkMike View Post
Hey guys!
Make sure your white balance is right, and have your shutter speed up high, maybe around ( TV 250) or higher, depending on light.
chops411 is offline
post #472 of 476 Old 02-02-2011, 03:31 AM
akaTRENT's Avatar
Hey guys looking for some help here with a possible mic issue.
Whenever I use external mics with my HFS 100 there is a ton of hiss.
It happens with the DM100 which i promptly returned for a lav (audio technica at898) but I am still having the problems. The hiss with external mics is worse than the built in mic, and no matter how I set the levels I can't seem to fix the issue.
Any suggestions would be appreciated.
akaTRENT is offline
post #473 of 476 Old 03-16-2011, 04:32 PM
zero7404's Avatar
can the S10 be able to support 64GB and 128GB SD Cards ?
once prices come down a bit, i'll go for one of these cards, it's much easier to pull the card and put it in the pc than set up the charger, usb cable and connect to pc to transfer files over.
zero7404 is offline
post #474 of 476 Old 08-05-2011, 10:56 AM
lt-cartman's Avatar
Hi all
Toolman here, after using a mates canon hfs10 for some live gig recordings and being very impressed with it. I just got my very own canon hfs10 yesterday from E-bay got the hfs-10 & a spare official Canon BP-819 battery a case, LCD hood & the canon WD-58 .07x58 Wide angle lens for 599 delivered - well chuffed I am :-).
I'm trying to match up the white balance with my hacked Panasonic GH1 - With the Panasonic GH1 I can input custom figures for the white balance say 4400 - which is important for me, as well as selecting the usual sunlight, shade etc settings.
So to my question does anyone here on the forum know what the equivalent degrees Kelvin settings are for the canons built in white balance pre-sets (looked in manual but it does not state them)
This way I can select the incandescent setting on the canon and just input the equivalent Kelvin setting on the GH1 (instead of risking the following scenario) - that the white balance setting for say incandescent is slightly different for canon than Panasonic.
Thanks in advance
Toolman
lt-cartman is offline
post #475 of 476 Old 11-21-2011, 01:28 PM
rudy4rail's Avatar
Did you ever find a good mic? I'm looking at DM-100 but open to other options. I read it gave you problems. Thx.
rudy4rail is offline
post #476 of 476 Old 12-30-2011, 05:39 PM
lottel's Avatar
I have an HF S100 and was wondering if I can get some help with the following concerns:
1) do you have an alternative software that can import, organize, and store clips (better version of Pixela)
2) what is the best way to archive clips?
3) can you edit and then render the clips to a compressed version to make it play smoother in the computer
thanks a lot for your future responses
lottel is offline
Reply Camcorders
