The Official Sony HDR-CX550V Owners thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 2289 Old 03-25-2010, 07:14 AM
mibcc's Avatar
Originally Posted by dblitz70 View Post
Excellent input, thanks! If I recall, if you have iAuto on, it detects that you're using the tripod and activates 'tripod mode'. Did you happen to notice a tripod icon while you were testing?
I did not mention this fact, but yes you are right about the icon.
So I am guessing that the i-auto is always trying to get the best filming conditions possible, that include turning OIS to off if no movement is detected !
mibcc is offline
post #632 of 2289 Old 03-25-2010, 07:42 AM - Thread Starter
dustindu4's Avatar
Has anyone else noticed that when in a low lit room, if you zoom in on something, the picture gets darker than when you're zoomed all the way out?
dustindu4 is offline
post #633 of 2289 Old 03-25-2010, 08:29 AM
dblitz70's Avatar
I would expect to see this yes. If you view the camera info on the file as you zoom in, you would probably see the aperture at minimum of 3.4, the gain and the shutter speed would change as you zoom in. The gain would top out at maybe 18db?, and the shutter speed would auto limit to 1/30th. At that point, the camera is out of options to compensate for the dark room. As you zoom in, you are getting less and less light onto the sensor as more of the image coming into the lens is going to waste.
dblitz70 is offline
post #634 of 2289 Old 03-25-2010, 09:00 AM
nahtanoj's Avatar
I only have the two cameras to compare. Oh well.
The FX1 can go down to 2.8 and the CX550v could only go down to 3.4 in this example. I really should have stopped the FX-1 down to the same fstop to make it fair, sorry. My conclusion is that the CX's predilection for using gain at the drop of a hat gave this shot a lot of noise. This was a fairly well lit room, and the FX1 was able to use the ambient light far better. The CX was able to achieve a decent bokeh effect however. If the FX1 was on 3.4, it would probably be a draw in terms of Bokeh. The FX1 is 3x 1/3 ccd and the CX550v is 1x 1/2.88 cmos. I wish I had a 1/4inch CMOS to test against.
PS. Best beer I can find on the market.
I'm sure this is obvious to some, but can you help me understand how to get the best Bokeh effect on the 550v (which I still didn't get yet, but am getting soon). Do you just go down an fstop or two to narrow the filed of view, thereby blurring the background? Can you manually narrow the focus on the 550v and does it then go into auto (pretend) shutter mode (I say pretend, bc it's not a mechanical shutter but - I think - an electronic simulation of a shutter with the sensor). Would you share the light conditions and settings you used to get a decent bokeh? Not just Fstop, shutter, and light conditions, but also frame rate and transfer/recording speed (Mbps). Thanks much!!
Jonathan
nahtanoj is offline
post #635 of 2289 Old 03-25-2010, 09:09 AM - Thread Starter
dustindu4's Avatar
yeah that makes sense because when I zoomed in and switched to manual, the manual settings got more limited
post #636 of 2289 Old 03-25-2010, 09:22 AM
dblitz70's Avatar
By setting your aperture / iris to be the smallest number / widest hole, you minimize your depth of field and therefore maximize the bokeh. By distancing yourself as much as possible from the subject, as well as maximize the separation between the subject and the background, you also maximize the effect. To this end, the cx550v has the strange little feature, Tele Maco mode. It pretty much zooms all the way out, and sets the fstop low so you get the max bokeh. It's weird to use though because if you touch the zoom at all, it cancels the mode. You end up having to frame your shots by moving the camera.
Shutter does not have anything to do with bokeh. It only helps you compensate for exposure since you would have set your aperture at it's lowest setting (f3.4). As far as fiddling with your focus, it's not the best way to go. Trying to move the 'field of focus' manually so that the subject is at the back of the field is what I think you mean, but more likely than not, you'll end up with partial focus. There is only one point within the field of focus that is truly in focus. Things further or closer to that point are more or less in focus depending on your depth of field. Worry more about separating you subject from the background or choosing subjects that have good natural separation. The spot meter/focus thing is great though. Once you've set up your shot, use that feature to lock your camera onto that subject. That's a convenient little tool I like for composed shots.
Anyone else have some tips?
dblitz70 is offline
post #637 of 2289 Old 03-25-2010, 09:28 AM
nahtanoj's Avatar
Excellent, dblitz70! Thanks for that. I don't think I can wait any longer to order. I want to buy from B&H, but I still have a $60 credit from Amazon. Maybe I'll buy the camcorder from B&H and an extra battery from Amazon.
Does anyone that carries both a DSLR (I have a Nikon D80) and a camcorder have a suggestion for carrying them both (esp since the 550v doesn't fit in a pocket)? I may just put it into my camera bag, but I may have to sacrifice bring a lens then.
Jonathan
nahtanoj is offline
post #638 of 2289 Old 03-25-2010, 10:09 AM - Thread Starter
dustindu4's Avatar
at least call B&H and see if they'll match amazon's price of 1099, I bet they will
or this place
http://www.centraldigital.com/Produc...0129&l=Froogle
post #639 of 2289 Old 03-25-2010, 10:37 AM
Dave Mack's Avatar
B+H is a good store. they often will as long as you can easily show the other price.
Dave Mack is offline
post #640 of 2289 Old 03-25-2010, 10:41 AM
Dave Mack's Avatar
Originally Posted by tingham View Post
Very Nice! I'll tell you , this cams OIS is great when walking around.
Thanks! I will probably keep the camera in manual focus mode for those types of shots as the "blister" effect can happen and ruin an otherwise good shot. The auto-iris seems good. I hope to have the stabilizer tom'w night and will do the same shots with it, with and without OIS on.
post #641 of 2289 Old 03-25-2010, 12:59 PM
mibcc's Avatar
Yes I have noticed this, it has to do with the total light being captured by the camcorder and the adjustments it's trying to do in i-auto. Check out link 633 from dblitz70...
Check that effect on my fist video I did with my CX550:
http://www.youtube.com/watch?v=pfRdCOYUcrQ[/url]
mibcc is offline
post #642 of 2289 Old 03-25-2010, 01:09 PM
mibcc's Avatar
You have surely done some DSLR before !
mibcc is offline
post #643 of 2289 Old 03-25-2010, 01:20 PM
Secondlaw's Avatar
or this place
FYI... This is the 64gb version for 1099.95 and not the 240gb version. You can get the 240gb version at ABES of Main for a bit cheaper and they actually lowered the price today!
http://www.abesofmaine.com/item.do?i...&id=SNHDRXR550
Secondlaw is offline
post #644 of 2289 Old 03-25-2010, 01:31 PM
Secondlaw's Avatar
So i'm having a problem deciding between 3 cameras...
One of my choices is the XR550v. I've been reading this thread and read a bunch of things about this camera.
What I haven't seen yet is someone saying, "WOW, This camera is the BOMB!!!!" So please, help me make my decision. Is this camera everything you expected it to be. Does it take movies that you're really pleased with? Are you happy you purchased this one over some of the other ones available, and why?
post #645 of 2289 Old 03-25-2010, 02:03 PM
Dave Mack's Avatar
I've had mine for one day. So far there are things I like and things I wish it had. I used to be in manual mode almost all the time when I shot.
With this you can only have manual control of one feature at a time, focus, aperture etc...
I used to have a vx2000 that I paid $2400 for and it was great but the head(s) went awhile back and it would be a $5-600 repair. Also it was 4x3 SD and soon to be obsolete. I think what this camera can achieve for $1020 shipped, (Tiger Direct via Bing cashback) is pretty phenomenal. If I had $3K I would probably get something more like this...
http://www.bhphotovideo.com/c/produc...Camcorder.html
but I don't so for me it was a bit of a compromise for what I would ideally have wanted and what I did get.
more impressions soon.
post #646 of 2289 Old 03-25-2010, 02:14 PM
Secondlaw's Avatar
Just looked at bing cashback on tiger... still comes up as 1399.00.
post #647 of 2289 Old 03-25-2010, 02:27 PM
Delirious's Avatar
http://www.camerakings.com/products/...30/HDR-XR550V/
It's where I got mine. It arrived sealed, USA model and in working condition. Really no problems at all with the camera. Salesman are pushy and I had to ask them to remove the 6% handling and insurance before I bought it.
Delirious is offline
post #648 of 2289 Old 03-25-2010, 03:22 PM
nahtanoj's Avatar
Just finished ordering:
-CX550v
-travel charger
-FV70 battery
-2 pack Tiffen filters (37mm) UV and circular polarizer
-1.7 Sony Telephoto lens (no external threads, which is a bit odd, since I wanted to put at least a UV filter for protection)
-WD Passport 1T HDD (I was going to go with a LaCie 1TB 7200RPM with bumpers) for the same price, but the size difference is astounding (the LaCie is about 4.5x8xsomething, and the WD Passport is the size of a Blackberry - 4.5x3x.5 or something like that)
Xtended warranty (Sucka!) Maybe I won't use it, but it's the version that you can (in theory) run over the camera or lose it in a lake. I'll be taking it to the Arctic and chasing bear and moose, so I might drop it!
I can't wait to get it and try it out!
Jonathan
nahtanoj is offline
post #649 of 2289 Old 03-25-2010, 03:54 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
Originally Posted by Delirious View Post
1129.99
Their selling the CX550V for $999.00....Geez!
Go Phillies! Go Eagles! Go Sixers! Go Flyers!
tingham is offline
post #650 of 2289 Old 03-25-2010, 05:13 PM
Webmonkey's Avatar
Quoted: 52 Post(s)
Liked: 31
one question - if you put a wide or tele adaptor on your camcorder lens - is light lost in the same way, as if you use a tele converter on a SLR???
How about sharpness etc,???
Webmonkey is offline
post #651 of 2289 Old 03-25-2010, 06:34 PM
dblitz70's Avatar
With a wide adapter, since the outer diameter of glass is wider and you are using all of it, you are condensing a larger swath of light down onto the chip. With a tele-converter you are usually taking about the same amount of light and using glass to enlarge the image, there by using a smaller portion of the available light.
That is my understanding of lenses from use of wides and tele's, someone please correct me if I'm wrong.
dblitz70 is offline
post #652 of 2289 Old 03-25-2010, 06:54 PM
dblitz70's Avatar
-CX550v
-travel charger
-FV70 battery
VMC-UAM1 cable to connect your Passport. Check earlier in this thread for more info.
http://www.bhphotovideo.com/c/produc...ter_Cable.html
dblitz70 is offline
post #653 of 2289 Old 03-25-2010, 06:58 PM
mibcc's Avatar
The same logique applies has DSLR cameras, the quality wile affect the HD quality.
If you buy 5$ UV or other cheap lens you will get the results you paid for !
On my DSLR theirs a lens up to 10,000$ !!!!
The closer you get down F2 range, the more they cost !
Check the specs and get the one that has the best/price you want to pay...
mibcc is offline
post #654 of 2289 Old 03-25-2010, 07:18 PM
David Sholle's Avatar
I think this is basically correct, and it certainly seems logical, but I remember being involved in a similar discussion many years ago with a lens designer, who said it isn't quite as simple as that. However, for the purpose of this discussion, it should be fine.
I remember with SLRs that if you got a 1.4X tele-converter lens that mounted between the camera and normal lens, that would increase the focal length by a factor of 1.4, and decrease the light gathering power by one f/stop (which is a factor of 2 in incoming light). This makes sense since you are viewing an actual area whose vertical or horizontal linear dimension has decreased by a factor of 1.4, and whose area has decreased by 1.4 squared, or 2.
David Sholle is offline
post #655 of 2289 Old 03-25-2010, 07:58 PM
Dave Mack's Avatar
That's the XR550V, a different model with a hard drive. The cx550V is $1199 and when the 15% cashback was in effect the other night it totaled $1019.
post #656 of 2289 Old 03-25-2010, 08:02 PM
Dave Mack's Avatar
http://www.resellerratings.com/selle...-p2-s1-d1.html
read some of the reviews at resellerratings.com. I would never use a company like that. The phone call to "verify" the order and the hard sell and the BS about no warranties or the batteries not working. If you somehow stay strong and get your order for all you know it's B stock or gray market.
That happened to me once. Never again.
post #657 of 2289 Old 03-25-2010, 08:21 PM
Webmonkey's Avatar
Quoted: 52 Post(s)
Liked: 31
Before xmas when I was looking at the CX505, I was also looking at the Sony 0,7x wide adaptor, but now the CX550 already has that 29mm wide
post #658 of 2289 Old 03-25-2010, 08:45 PM
Delirious's Avatar
Yes, please, use at your own risk. I did get a factory sealed unit - not B stock, but the savings allowed me other accessories and kept me in budget.
post #659 of 2289 Old 03-25-2010, 08:59 PM
nahtanoj's Avatar
I asked the B&H sales rep about this cable, as I read it on this thread, and he told me that the 550v came with a cable for copying, so I didn't need it.
Now I'm confused. Is there a cable that comes with the 550v and if so, is it for the camcorder to a TV?? Is it a mini HDMI to HDMI - I hope it isn't since he sold me a separate mini HDMI to HDMI for my TV. It looks like the cable you referenced (thanks by the way) is for a USB into the adaptor into the 550v, but I'm not sure. Please help me understand.
Jonathan
nahtanoj is offline
post #660 of 2289 Old 03-25-2010, 09:04 PM
Delirious's Avatar
for purposes of direct copy from the camcorder to an external drive, my box didn't come with a cable(vmc-UAM1). It's sold seperately. The box did come with the usb cable to copy files to your computer. Hope that answers your question
Reply Camcorders
