SPEED HD-50Z HD DV Camcorder with touch display - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-28-2010, 01:05 PM - Thread Starter
tuytuy's Avatar
found on tiger111hk.com
Share your review ..
the SPEED HD-50Z High Definition H.264 DV Camera Camcorder
Stronger function . with 1080p record and 3" touch LCD and support SD , 50x zoom
. 12.0 MegaPixel (Max) / 5M CMOS Sensor
. Support 50X Zoom ( 5X Optical / 10x Digital )
. 3" TFT LCD Touch Display (16:9)
. High Definition 1080P(30fps) Video Recording
. Support Dual Video Recording for Internet Video Sharing
. Support NTSC/PAL/HDMI Output
. Support SDHC Card up to 16GB Class 6
Specification Sensor 1/2.5" 5.0 Mega-Pixel Sensor Max. Resolution Fine 12.0 Mega-Pixel ( Firmware Interpolation ) Lens 5X Optical Zoom Lens
Wide : F3.5~F32, f=6.8mm
Tele : F3.7~F33.8, f=34mm ( 38-190mm equivalent to 135mm ) Zoom Movie 50X (5X Optical Zoom, 10X Digital Zoom)
Camera 50X (5X Optical Zoom, 10X Digital Zoom)
Still Image Playback Digital Zoom Max. 8X Focus Range (Normal) Wide: 10cm ~ infinity; Tele: 1m ~ infinity
(Marco) Wide: 2 ~ 80cm White Balance Auto / Sunny / Cloudy / Tungsten / Fluorescent Exposure -2.0EV ~ +2.0EV Color Effects Color / B&W / Sepia LED Light (Video) On / Off
Effective Range 0.5m ~ 1m Strobe (Camera) Auto / Forced / Off LCD Display 3.0" 16:9 TFT LCD Touch Display ( 960 x 240 Pixels ) Storage Media Built-in 128MB Flash Memory ( 80MB available ) Memory Card Slot SDHC Card (Up to 16GB Class 6) Movie Clips Format H.264 (MOV)
Resolution 1080P(30fps), 720P(60fps), 720P(30fps), WVGA(60fps), WVGA(30fps), WQVGA(240fps)
Dual Video recording simultaneously : 1080P+WQVGA, 720P+WQVGA Still Image Format JPEG (EXIF2.2)
Resolution 1M / 2M / 5M / 12M ( Interpolation )
Aspect Ratio : 4:3 / 16:9 / 3:2
Support Continuous Shots
Self-Timer : Off / 5sec / 10sec Electronics Image Stabilizer Yes Interface PC : USB 2.0 (High Speed)
Video : NTSC / PAL / HDMI (1080i Output) Setup Language English, Traditional Chinese, Simplified Chinese, German, Italian, Spanish, French, Turkish, Portuguese, Dutch, Japanese, Russian, Korean and Arabic. Auto Power Off Off / 5 min / 10 min Shutter Still : 1/2 ~ 1/2000
Video : 1/30 ~ 1/4000 power Source NP-120 Li-ion battery Accessories Li-ion Battery
USB Cable / AV Cable
HDMI Cable
110-240v Battery Charger
CD-ROM driver disc
Camera Pouch
User's Manua Weight 292g (Batteries Exclusive) Dimension 57 (W) x 70 (H) x 129 (D)mm Supported OS Windows Vista / XP (32bit)
tuytuy is offline
Reply Camcorders
