WVGA vs HD questions please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-06-2010, 07:03 AM - Thread Starter
davyo's Avatar
I have a Kodak Zi8, shoots in HD and WVGA and I realized Im not really sure what the advantages are in using WVGA besides getting more room on a SD card.
One thing I was wondering is for YouTube stuff does WVGA load up faster than HD footage ?
What are the advantages, if any, using WVGA instead of HD (720p, 1080p).
Sorry for what Im sure are dumb questions, I just dont know that much about WVGA.
Thanks in advance
Cheers
Davyo
davyo is offline
post #2 of 3 Old 02-06-2010, 08:53 AM
Shadow_7's Avatar
according the "$ man ffmpeg" WVGA == 852x480. Which for all intents and purposes is DVD quality. Plusses and minuses. If you're putting the content on DVD, that's a lot quicker turn around (less data). It takes up less space on the HDD, it takes less resources (CPU + RAM) to process (less data). But it is less data. You can't really add information to make it 1080p or even 720p. Moot if you don't need /want that. Or if you need longer recording times and such more than HD content.
WVGA = 852x480
720p = 1280x720
1080p = 1920x1080
Shadow_7 is offline
post #3 of 3 Old 02-06-2010, 08:53 AM
Shadow_7's Avatar
WVGA = 852x480
720p = 1280x720
1080p = 1920x1080
Shadow_7 is offline
Reply Camcorders
