The Official Panasonic HDC-HS/SD/TM700 Owners thread - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 03-13-2012, 09:25 PM
Steve Cebu's Avatar
Just be sure to have plenty of light when you take still pics with a GoPro. It's a great camera but it really needs a LOT of light.
Steve Cebu is offline
Old 03-13-2012, 09:44 PM
Tom899's Avatar
Quoted: 87 Post(s)
Liked: 25
I have a TM700 and wish to install it on my bike handlebars with a RAM mount to video some rides. I was thinking of just getting a GoPro2 HD but thought I should at least try out the TM700. The GOPro has a 170 degree viewing angle. Does anyone know if this can be duplicated on a TM700 with a wide angle lens? I do have a .5x Raynox but have no idea how this compares?
-Tom
Tom899 is offline
Old 03-14-2012, 05:46 AM
Steve Cebu's Avatar
You will need a vibration dampening mount for your TM700. The OIS will not compensate for that level of vibration. I had a GoPro it was a great little cam for outdoors on a bright sunny day. If you get the right mount you can easily mount the TM700.
Don't skimp and buy a cheap mount or your camera will get destroyed. Even the GoPro's fall off their mounts which is how mine was destroyed.
Old 03-14-2012, 08:31 AM
bsprague's Avatar
Quoted: 500 Post(s)
Liked: 182
Where would I find a quality vibration dampening camcorder mount? I googled a bit and found little that was specific to camcorders.
Bill
bsprague is online now
Old 03-14-2012, 09:01 AM
Ungermann's Avatar
Quoted: 522 Post(s)
Liked: 68
I would not subject the TM700's OIS to such harsh vibrations. I would rather get a cheap camera with EIS.
Ungermann is online now
Old 03-14-2012, 07:08 PM
Tom899's Avatar
Quoted: 87 Post(s)
Liked: 25
It's actually a 3 wheel tadpole trike with full suspension for road use only but you may be right, I should just get a GoPro?
-Tom
Tom899 is offline
Old 03-14-2012, 07:10 PM
Tom899's Avatar
Quoted: 87 Post(s)
Liked: 25
I have a RAM mount which is really good but not damped. I have a ICE trike with full suspension that I plan on mounting it on, but maybe I should just get a GoPro?
-Tom
Tom899 is offline
Old 03-14-2012, 09:11 PM
Steve Cebu's Avatar
Well a GoPro is designed for that sort of usage but you said you wanted to use your TM700.
The GoPro can handle the vibrations but be sure the mount is secure before you take off and you can even secure it more.
GoPro makes a great camera but their mounts are not the best.
Old 03-14-2012, 09:36 PM
Tom899's Avatar
Quoted: 87 Post(s)
Liked: 25
Thanks for the tips. I have not been using my TM700 much at all so thought I would use it on my trike, but I would hate to ruin it so maybe a GoPro would be a better choice. I do have good RAM mounts for either choice. I plan on overlaying the video with GPS and DashWare.
-Tom
Tom899 is offline
Old 03-15-2012, 07:22 AM
Steve Cebu's Avatar
You should be fine but no matter how good the cam is, if it falls off, it's not going to be pretty. That's why movie companies buy GoPro's by the case and use their own mounts instead of GoPro's.
Old 03-15-2012, 03:01 PM
Tom899's Avatar
Quoted: 87 Post(s)
Liked: 25
Yes, RAM mounts are some of the best, they are used professionally on race cars, motorcycles, planes, trains, etc... Pretty much bullet proof. Not lite though.
-Tom
Tom899 is offline
Old 03-23-2012, 10:35 PM
BrianSiano3's Avatar
Title says it. What's the camcorder's audio sample rate? 19200? 44800?
BrianSiano3 is offline
Old 03-24-2012, 04:06 AM
pjc3's Avatar
From Mediainfo: 384Kbps, 48KHz, 16 bit, 6 Channels, AC-3
pjc3 is offline
Old 03-25-2012, 03:20 AM
sparcling's Avatar
Hi,
I have an European HDC-TM700. The problem for me with this camcorder is that it does 50p instead of 60p. 50p works fine on my television but for use on computers and other portable devices 60/30p makes more sense. I'm quite sure that this can be fixed by replacing the EEPROM contents from my European TM700 with that of a USA TM700.
I've figured out how to go into the service mode menu of the camcorder as well as how to access an additional 'FACTORY MENU'.
It seems that the firmware might do both 50p and 60p since when going into a 'physical button and sensor check' menu it shows an on-screen 60p button being pressed when pushing the physical 50p button on the camera itself.
Inside the 'FACT(ORY) MENU' it's possible to view, write, watch, update, dump EEPROM contents, RAM etc contents.
My question is the following. Would somebody from the USA with a HDC-TM700 (not the SD or HS model) be willing to dump his/her EEPROM contents for me so that I can possibly convert my European TM700 into a USA one with 60p mode ?
If terms like firmware/EEPROM etc sounds like some alien language to you, please do not reply since in theory it is possible to 'brick' your camera when you do not know what you are doing.
If you are willing to help please PM me for the details.
P.S. having access to the RAM/EEPROM could in theory allow access to features that might have been disabled on this camcorder to diversify it from more expensive pro camcorders at the time of it's release... So I wonder why this hasn't been explored more (nothing to find on Google).
sparcling is offline
Old 03-25-2012, 09:10 AM
I truly wish this was something that hackers, such as Vitaly Kisilev, would do. Sadly, the TM700 isn't as big a seller as the GH2, which he's hacked brilliantly.
Old 04-04-2012, 12:30 AM
aesooi's Avatar
Hi guys,
New to this forum thing, need some help.
Have my HS700 for over a year now, love it very much. Last weekend while videoing my son's basketball game, it came up with error message "error occurred. Please turn unit off, then turn on again".
I turned the unit off and on and I can 'playback' but when I turned to motion picture mode, it won't let me zoom or do anything, after 1 min, the same error message came up. I tried switch it to using the sd card but that didnt help. same error.
I then went back to playback mode and deleted the videos. even went as far as reformatted it. format went well but same error again when videoing.
I went looking for answers and purchased the service manual to seek more help. Tried to go into service mode as stated in the manual (zoom/IA/Menu keys for 3 secs) but that didnt work either.
so now I am seeking help from you experts. failing this I will send it to pana service centre which will definitely cost me a few hundred bucks. My wife will not be too happy with it I am sure.
thanks guys
aesooi is offline
Old 04-04-2012, 03:58 PM
Steve Cebu's Avatar
Try calling Panasonic support first which is free and see if they have a quick fix for you. From the sound of it, it sounds like it's overheating.
Old 04-04-2012, 07:44 PM
aesooi's Avatar
Thanks Steve. They need to have a look at it which is A$77 then they will tell me what's the problem and whether I want to go ahead with the fix , which will definitely cost more(parts and labour).
cheers
aesooi is offline
Old 04-04-2012, 08:25 PM
Steve Cebu's Avatar
cheers
That's crazy money. They can diagnose if it is a known problem on the phone. I guess once it's out of warranty that's the end of their helpfulness.
I have had 2 canon cameras both dropped at different times and Canon charged a flat fee to fix them and both worked like new and I still have one of them the other I gave to my wife's family to use.
They love it.
Cost to fix these things usually has a flat rate at least Canon does. The retractable lens on my SD400 was literally bentand it was fixed as good as new. Yours might be cheaper to fix. It can take up to 6 weeks to get the camera back tho.
Old 04-06-2012, 01:10 AM
aesooi's Avatar
They will get back to me on the 11th(being Easter holidays and all), hope the damage isnt that great. The guy didnt think it was a big one since I can still playback. so fingers cross.
I should consider Canon next time. the XA10 looks nice.
thanks man.
aesooi is offline
Old 04-06-2012, 06:39 AM
Steve Cebu's Avatar
thanks man.
Sure thing although unless you need the XLR inputs the HF G10 is a better deal price wise.
Old 05-04-2012, 09:57 PM
jmone's Avatar
Liked: 37
Anyone got a link to the Service Manual for a HS700, I'm thinking of swaping the HDD out for an SSD but I've found no discussion on the Web of such a thing so far.
jmone is offline
Old 07-30-2012, 03:22 PM
pas123's Avatar
I have the HDC-TM700 and after looking at some awful footage (jittering pan with O.I.S) look like i need to upgrade the firmware,
anyone has the firmware already? and how can I access the hidden service menu?
Thanks a lot..
pas123 is offline
Old 08-02-2012, 10:50 AM
pas123's Avatar
I have noticed that HD writer V 4.0 is so much better than the older 2.1 version
and work great with ths HDC-TM700..
pas123 is offline
Old 08-02-2012, 11:19 AM
bsprague's Avatar
Quoted: 500 Post(s)
Liked: 182
I wish there was a way to get it as an upgrade. My version 2.6 is limiting. Panasonic seems to not want to let that happen. Perhaps the reason is that Panasonic sees the software part of the total product and wants customers to buy new cameras just to get the additional features from the new software.
Bill
Old 08-02-2012, 11:26 AM
markr041's Avatar
Quoted: 771 Post(s)
Liked: 241
It is interesting that Sony upgrades its "free" camera and camcorder software - which is one package - continuously (some did not like the upgrades) and it works with their older cameras too. Some features of the Sony software are only added depending on the camera (3D for 3D cameras, etc.). Panasonic seems to provide different software with different cameras and you are stuck.
markr041 is online now
Old 08-02-2012, 11:59 AM
bsprague's Avatar
Quoted: 500 Post(s)
Liked: 182
Originally Posted by markr041 View Post
... (some did not like the upgrades).....
Like me. The first upgrade went well and added some 1080p60/AVCHD 2.0 support. The second, to Play Memories did not go well. I would have liked the new features, but after installation, it said none of my existing files were compatible. It would not even load a snapshot. I know it should have worked, but it didn't. Maybe I'll try again.
Bill
Old 08-02-2012, 12:11 PM
markr041's Avatar
Quoted: 771 Post(s)
Liked: 241
I would try again. I upgraded on three computers and had no problems reading any photo or video files - even the ones from Panasonic camcorders and older Sony cameras/camcorders. You just tell the software (by clicking) which folders to look at.
(By "some" I meant you!)
Old 08-02-2012, 09:15 PM
bsprague's Avatar
Quoted: 500 Post(s)
Liked: 182
I figured as much!
Old 08-28-2012, 04:28 AM
myg
myg's Avatar
Please, can you tell me - does HD writer reencodes 1080\50p video when it copies it to external SD card connected to PC? Or it simply creates AVCHD directories and copies m2ts to SD?
myg is offline
