Official Sony HDR-CX110/CX150/XR150 Owners Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 101 Old 04-10-2011, 09:13 AM
Moviemaker4741's Avatar
Originally Posted by edmellnik View Post
just bought a cx150 for my daughter who is expecting...
Trying to figure it out so I can teach her how to use it.
Since her computer and mine are on xp sp2 the PMB does not seem to want to
deal with avchd files.
So my question is - is there a way to unwrap the BDMV file into something I can use or play on my computer?
I am a professional videographer and I am assuming this BDMV file is much like the BPAV file I get on my pro sony ex1. The files have to be unwrapped with a utility in order to have access to the clips.???
Your XP will not process Mt2 files, if you keep XP you must convert to the AVI or some other format.
Moviemaker4741 is offline
post #92 of 101 Old 05-30-2011, 01:49 AM
phieubac's Avatar
hi all
I have question about sony cx150. I record my vacation on cx150. I used internal memory. I transfer the movie to laptob win 7, and everything is fine. However, I have some clip that I record on the external memory. I'm unable to transfer it to my laptop via PMB. So is there any way that I can transfer it.
thanks.
phieubac is offline
post #93 of 101 Old 05-31-2011, 06:15 AM
Anubys's Avatar
Originally Posted by phieubac View Post
hi all
thanks.
You probably already did this but did you connect to the USB correctly?
I have a 350, so my interface may be different. When I connect mine, I can select to connect the USB to the hard drive or to the memory card. Those are 2 distinct buttons on the screen.
Anubys
Anubys is offline
post #94 of 101 Old 05-31-2011, 09:19 AM
Calgadan's Avatar
Hi,
I have just imported files from my HDR-CX110 to the computer, edited and rendered them using Corel Videostudio pro X3. I would like to use the camcorder as a player and connect it to my tv. Is there a way to return the finished movie to the camcorder?
Thank you for your help.
Calgadan
Calgadan is offline
post #95 of 101 Old 05-31-2011, 10:07 AM
phieubac's Avatar
when I connect it to computer I show connect internal memory and external memory. The internal memory connect it show clip from internal, and when I select connect to external it show clip with big X. Can't not transfer.
phieubac is offline
post #96 of 101 Old 06-06-2011, 10:12 AM
sdchap's Avatar
I'm in the same boat of quandary! I'm looking for a good camera for my 14 year old who is crazy about film making and has basically worn out our old Hi-8 Sony handycam.
The Amazon user reviews of the HDR-CX110 are for the most part glowing. The reviews of the HDR-CX130 are relatively lousy.
If both cameras have the same sensor, shouldn't the images look the same? (I know there are some differences in usability, but...)
sdchap is offline
post #97 of 101 Old 06-08-2011, 08:19 PM
kablooie's Avatar
since the price is dropping on the cx110 and for a good beginning camera, i'd go with that one. i love my cx110 and wish my computer was faster to view the HD files. seeing that child is 14, this i think, is a good place to start.... btw: my cx110 was a HUGE step up from my prior camera.... a Sony analog Hi8, lol.
kablooie is offline
post #98 of 101 Old 05-26-2012, 02:40 PM
spongebob's Avatar
Quoted: 38 Post(s)
My SD card won't stay in the slot. Just springs out and doesn't latch in. Any ideas?
HDR-CX150.
thx
bob
spongebob is offline
post #99 of 101 Old 01-25-2015, 07:27 AM
MasturB's Avatar
Can someone tell me if I can use this camera during a live production? Wouldn't need to record, just need the feed from the camera to connect to a computer.
And, does Sony sell any remotes for this? I have the CX110, and if I can't find a camera man, would like to be able to zoom in and out remotely at least. Can either be wired remote, or wireless.
MasturB is offline
post #100 of 101 Old 01-26-2015, 09:33 PM
fishywishy's Avatar
Quoted: 17 Post(s)
sony did sell a wired lanc that would plug into the av port
fishywishy is offline
post #101 of 101 Old 04-25-2015, 09:33 AM
rman66's Avatar
Quoted: 12 Post(s)
I have a Sony CX150 .. it has been in my shelf for about 3 or 4years unused. Now, I just charged the battery and turned it on and trying to take video.
The image quality is horrendous.. extremely grainy and can barely make out what the image is about.
Any suggestions on whether there is a fix for this?
thanks.
rman66 is offline
Reply Camcorders
