Zoom H1 recorder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-03-2010, 06:42 PM - Thread Starter
Paulo Teixeira's Avatar
Quoted: 78 Post(s)
Liked: 44
I'm sure a lot of you have seen this already but if you haven't, you should check it out.
http://www.samsontech.com/products/p...fm?prodID=2053
Paulo Teixeira is offline
post #2 of 6 Old 06-03-2010, 07:23 PM
Chevypower's Avatar
Liked: 40
Yeah I wouldn't mind trying one out for recording atmos sound. I don't think I would use it for anything else.
Chevypower is offline
post #3 of 6 Old 06-03-2010, 10:04 PM
Shadow_7's Avatar
It's likely better than the camcorders audio. As I spy an H4 on craigslist for $100.
Shadow_7 is offline
post #4 of 6 Old 06-03-2010, 10:55 PM
Dave Mack's Avatar
paulo, i just got the zoom h4n.
http://cgi.ebay.com/Zoom-H4n-H4-n-4-...item563c865eb8
will try it out this weekend. has good buzz.
Dave Mack is offline
post #5 of 6 Old 06-04-2010, 07:13 AM
davyo's Avatar
The Zooms Rock !!!!!
I been using a Zoom Q3 with all my video cam's for a while now,,, makes for some killer sound to go along with my HD video stuff.
Rumor has it that Zoom will be coming out with a HD cam with the same audio recording set-up as the Q3,,,,, a HD Zoom Q3 version.
Cheers
Davyo
davyo is offline
post #6 of 6 Old 06-19-2010, 10:38 AM
Dave Mack's Avatar
Finally used the Zoom4n a lot last night. Great unit with very good sound.
Reply Camcorders
