Panasonic HDC-TM700 camcorder bag/case - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 06-26-2010, 11:00 PM - Thread Starter
avbanger's Avatar
Can anyone recommend a case/bag for the HDC-TM700. I searched through the threads and most people are using the Lowepro Edit 110 but I want something that holds the camcorder vertically, no lying down horizontally. With the hood, a UV filter and the camcorder, it's pretty long and skinny (insert joke here)
avbanger is offline
post #2 of 32 Old 06-27-2010, 12:06 AM
postman's Avatar
I got the Tamrac 3392, http://www.amazon.com/gp/product/B00...ef=oss_product . Minimal case, just big enough to hold the camcorder itself (with the lens hood and a circular polarizer). I wanted someting to protect the camcorder but as small as possible, and this case is that
postman is offline
post #3 of 32 Old 06-27-2010, 04:11 AM
dhnj's Avatar
I got mine from Ebay Link:
http://cgi.ebay.co.uk/F27-Leather-Ca...item35a955606e
dhnj is offline
post #4 of 32 Old 06-27-2010, 06:46 AM
MaXGTS's Avatar
I was recently using the LowePro Edit 100 to store my TM700 vertically. Unfortunately, the bag was not tall enough to do this with the lens hood installed. Yesterday I exchanged the bag for the Edit 110.
MaXGTS is offline
post #5 of 32 Old 06-27-2010, 07:42 AM - Thread Starter
avbanger's Avatar
That's exactly what I was looking for. Thank you very much! Thank you for the other suggestions as well.
avbanger is offline
post #6 of 32 Old 07-12-2010, 09:03 AM
Smooth_J's Avatar
Found this thread cause I had the same question. I was about to get the edit 110, but looked tiny so I picked up the only thing they had after which was a edit 140. Is the edit 110 big enough for hood, a UV filter, the camcorder, 2 batteries, charging cradle and power cord? I had this for my previous camcorder, Canon HF100, but it seems that this Panny is smaller.
Smooth_J is offline
post #7 of 32 Old 07-23-2010, 04:04 PM
arcooke's Avatar
Anyone have any more recommendations? Perhaps something that will fit some basic accessories? (batteries, charger, cables, etc) that isn't too big?
arcooke is offline
post #8 of 32 Old 07-24-2010, 10:03 AM
bigtuna's Avatar
I bought the Lowepro Adventura 140 from Best Buy. Everything that came with the TM700 fits perfectly and it was cheap, $25 US. It's tall enough for the TM700 to stand up with the bigger battery and lens hood.
http://products.lowepro.com/product/...a-140,2160.htm
bigtuna is offline
post #9 of 32 Old 07-25-2010, 08:35 AM
jogiba's Avatar
Quoted: 513 Post(s)
Liked: 234
I use a laptop case to hold my TM700 with all of the cables (HDMI) , charger, Rode Stereo VideoMic etc.
jogiba is offline
post #10 of 32 Old 07-25-2010, 01:20 PM
Djizasse's Avatar
I got this for the cam alone:
http://cgi.ebay.co.uk/E787-Camera-Ca...item335def7134
And this for the cam, wallet, charger and a small tripod:
Samsonite Trekking 200
http://www.fotolab30.com/xcart/custo...UL-p-3150.html
Djizasse is offline
post #11 of 32 Old 07-26-2010, 09:01 AM
LuxZg's Avatar
I'm gonna go with this one, just looking at eBay for it.. I like having everything for my cam in one bag, and if I don't need some of the extras, I can always find something else to put in the bag if it's organized well I'll get back to you all when I get it..
EDIT: Hmmm.. .though the bag from Djizasse's link looks very nice to have when going out "light".. I'll think about it
LuxZg is offline
post #12 of 32 Old 07-26-2010, 09:22 AM
Djizasse's Avatar
And it's seems sturdy. The cam stays almost afloat inside the case. If by some accident I drop the case, I'm fairly confident the cam will be safe.
Djizasse is offline
post #13 of 32 Old 07-26-2010, 10:03 AM
LuxZg's Avatar
That's good to know. I like that little case more and more by the minute I always curse myself with my still cam because I can't put it anywhere because it's too big, perhaps TM700 and that case could be the solution
As for larger bag, I gave up from eBay.. sure it's 25$, but I can get several nice bags in local shops, and don't have to wait for delivery. Like Lowepro models Edit 120/120+, Clips 110/120, Rezo 110/120.
Since Adventura isn't available here, I think I'll go try Edit 120+. On it's own it's a bit bigger than Edit 110 that many people here use, but the "+" means it has one additional storage pouch that can be attached/removed as needed at the bottom of the bag. So if I want to pack a bit lighter, I can just detach the thing. Should cost me ~5$ than what they ask for Adventura 140 on the eBay, and I can get it after 1 day, not after 15. My vacation is nearing, so I'd rather have it early than late
I'll post few pictures when I get it and try it out a bit.
LuxZg is offline
post #14 of 32 Old 07-26-2010, 08:00 PM
HTung's Avatar
I mentioned this earlier. In case you need 1 bag to easily carry around with camcorder, small tripod, some filters, remote control, charger, and cable, you can have a look at Crumpler Jimmi Bo 300.
It works perfectly for my vacation last weekend.
In fact, when I go around, I leave the charger and cable at hotel and put the Canon G11 in it to take still picture.
The bag is not so much sturdy, but it protects the devices well and comfort to carry for a whole day.
HTung is offline
post #15 of 32 Old 07-27-2010, 09:40 AM
vsathish's Avatar
Djizasse,
If you have VBG260, could you please check whether the camera with the battery will fit into the small bag you linked above. If not, if you can check whether the camera fits in with the viewfinder fully extended, I would greatly appreciate it.
vsathish is offline
post #16 of 32 Old 07-27-2010, 01:54 PM
Djizasse's Avatar
It fits with the VF fully extended.
Djizasse is offline
post #17 of 32 Old 07-27-2010, 02:13 PM
vsathish's Avatar
Thanks for your prompt response. I will get that bag.
vsathish is offline
post #18 of 32 Old 07-28-2010, 10:52 AM
LuxZg's Avatar
I'm in a bit of a hurry, but I wanted to say I'm pretty amazed what I've managed to fit inside this Edit 120+ Photos later, but I got:
- TM700, AND Panasonic DMC-FZ7 in the main compartment (DMC-FZ7 is a compact high-zoom cam); it's a bit tight, but they fit (with the soft divider between them which is pretty thick)
- chargers with cables for both cam and still cam in the "+" bottom compartment (detachable, so when I don't need chargers with me, I can just leave that part of bag at home)
- extra battery for still cam
- USB SD-card reader
- I could easily fit TM700 USB cable, DC cable and probably remote as well
- SD cards, keys, mobile phone, money, driving licence etc.
... I've got nothing else to carry really
When on a larger trip, DMC-FZ7 still cam would go to it's own bag, but I am really glad that I can fit both in one bag, when going out or something, and I want to "pack light", and I can still fit my personal belongings in the case as well
One drawback though, with VBG260 battery (still haven't received it, but tried with VF extended) - I think that cam won't fit vertically. But it can fit horizontally with both VBG260 and lens hood. Of course, without still cam than, so when case is just for TM700. It would actually leave a lot of room on top of the cam.. I think in that setup you can put charger at the bottom, than the soft divider over it, than TM700 on top.
I'll make some pictures with few things inside the bag, and in few different "setups/scenarios" so you get the feeling. It's a great bag, and it cost me.. roughly 18$ here in the local shop in Croatia.
LuxZg is offline
post #19 of 32 Old 08-02-2010, 04:10 PM
keytrnr's Avatar
I got this one today too. Everything fits, I don't have the manual in the case, though it is snug putting all the cables in there. There are exterior pockets for extra batteries or memory cards. I'll probably keep it, but considering returning it for the Adventura 170. I don't really need to keep the multi A/V cable in there.
keytrnr is offline
post #20 of 32 Old 08-03-2010, 05:21 AM
LuxZg's Avatar
Ummm... if you DON'T need space for cables, you need smaller case.. so why going for larger 170 model? Or did you mean to write something else..
LuxZg is offline
post #21 of 32 Old 08-03-2010, 10:54 AM
keytrnr's Avatar
What I mean to say is that it is a snug fit for the cables, but since I do not need to carry all of them, I will just keep the case. Seems like a nice case.
keytrnr is offline
post #22 of 32 Old 08-03-2010, 11:56 AM
LuxZg's Avatar
Oh, ok, got that now sorry
LuxZg is offline
post #23 of 32 Old 08-05-2010, 06:04 AM
LuxZg's Avatar
OK, FINALLY I had time to do a proper "photo shoot" of this bag, and I actually made a pretty through review for all TM700 owners, but anyone else with a similar camcorder as well.
Just go to my album, and read the comments under the pictures. I hope you find it useful, as I just spent an hour doing it all
Link: http://s259.photobucket.com/albums/h...%20120%20plus/
LuxZg is offline
post #24 of 32 Old 08-09-2010, 07:24 AM
Djizasse's Avatar
Nicely done Lux
Djizasse is offline
post #25 of 32 Old 08-10-2010, 06:17 AM
LuxZg's Avatar
Nicely done Lux
In the meantime, I've "retired" my old still cam's bag. I've found out that I can fit everything I'll ever need for both still & video camera in that same bag, and still have some space left for some personal things... Really neat bag, and I'm happy with it I just hope that VBG260 won't cause lack of space suddenly
LuxZg is offline
post #26 of 32 Old 08-13-2010, 03:03 AM
LuxZg's Avatar
Well, my VBG260 extended battery arrived today. If I carry my still cam and TM700 in same bag, I can't put VBG260 ON TM700 and than into bag.. But if I put TM700 with it's original VBG130 in main compartment (with still cam), there is still enough space in bag's other pockets for VBG260, and all the equipment, and my personal stuff.. So I'm more than satisfied with this bag
LuxZg is offline
post #27 of 32 Old 09-14-2010, 11:51 AM
AVSWatcher's Avatar
AVSWatcher is offline
post #28 of 32 Old 12-02-2010, 01:49 AM
kimbahpnam's Avatar
Bump
Is there a case that will hold the TM700 + MKE 300 external mic or is it wiser to use a separate case for the mic?
kimbahpnam is offline
post #29 of 32 Old 01-29-2011, 02:07 PM
janico's Avatar
Guys,
Try Lowerpro Clips 120. I am so impressed, it is small enough yet it fits everything in it .
janico is offline
post #30 of 32 Old 01-30-2011, 09:08 PM
CarguyHere's Avatar
I have the Lowepro 120, but it tips over...
They also have one called the clip, and it has a sleeve for the camera. That might do the trick (and I would have prefered it over my 120, the 120 has an extra little bag that holds the charger, which I can take, or leave behind, very handy)
CarguyHere is offline
Reply Camcorders
