Frame Rate Troubles on Vixia HF200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-08-2011, 02:12 PM - Thread Starter
NorvenLeverone's Avatar
Hey, guys. I'm sorry if this has been discussed to death, but after all the searching I've done, I can't find a straight answer:
When I shoot in 24p, it mounts the images on a 60i file. For pulldown, it shows one frame twice, and the next 3 times. The picture quality is wonderful, especially when I play it on my PS3. But when it comes time to edit, I'd prefer to work in a 24p timeline. Pardon me if this is harsh, but Sony Vegas 8 does an atrocious job of doing 2:3 inverse telecine. Sometimes I can see artifacts from 3 different frames in one individual frame. Is there any way on Windows that I can do a decent 2:3 inverse telecine? Keep in mind, it's the same frames twice, then three times. The frames aren't made up of interlaced bits of other frames.
Much appreciated, whoever can give me a definitive answer
NorvenLeverone is offline
post #2 of 5 Old 01-08-2011, 02:22 PM
Quoted: 88 Post(s)
Liked: 32
Shoot in 30p: looks great, no pulldown needed.
xfws is offline
post #3 of 5 Old 01-08-2011, 02:50 PM
Dave Mack's Avatar
that didn't really answer his question. And you can't put a 30P edited clip, file, project onto Blu ray.
I think you need 'cineform
http://techblog.cineform.com/?p=806
Dave Mack is offline
post #4 of 5 Old 01-08-2011, 02:55 PM
Quoted: 88 Post(s)
Liked: 32
you're right.. It was a recommendation to avoid dealing with 24p as I didn't see the benefit with it, especially if posting on the internet...
but I didn't know that about BluRay and 24p...learned something new.
xfws is offline
post #5 of 5 Old 01-08-2011, 11:05 PM
Ungermann's Avatar
Quoted: 517 Post(s)
Liked: 68
Vegas removes pulldown for DV only, and also for Sony's type of HDV called 24A.
Cineform, Procoder, TMGEnc. If you want it for free try FFMpeg Batch Intermediate Creator.
Not true. You can put 30PsF (a.k.a. 2:2 pulldown) into 1080i30 project just the same way the camcorder records it. All decent modern Blu-ray players can process 2:2 pulldown. Or you can downres it to 720p and put into 720p60 with 2:2 frame repeat.
Ungermann is offline
Reply Camcorders
