Sony HDR-CX700V Shipping tomorrow, Anyone ordered one? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 334 Old 03-10-2011, 09:22 PM
Ken Ross's Avatar
Quoted: 5700 Post(s)
Liked: 6062
Originally Posted by djandrea View Post
no is pal 50p
BINGO! That 100% explains that odd stutter I saw. That makes this footage that much more impressive as I'm sure now it would be totally artifact free.
Ken Ross is offline
post #92 of 334 Old 03-10-2011, 09:25 PM
Ken Ross's Avatar
Liked: 6062
Originally Posted by lekom View Post
Are you sure about that?
The bottom image, as small as it is, is obviously sharper than the 550 image.
Ken Ross is offline
post #93 of 334 Old 03-10-2011, 09:27 PM
Ken Ross's Avatar
Liked: 6062
Originally Posted by Ungermann View Post
If you can afford $1,300 then just buy it. I am sure it is no worse than the Pana with more natural (as it seems) color rendition, with native 24p, with much better screen, with wider lens. I don't see a point of waiting for a review, really.
We are actually in total agreement on that one Ungermann. I am more impressed with what I've seen from the Sony than from what I've seen from the 900. Given there aren't many clips out there yet, it's not 100%, but based on what is, the Sony is really very impressive and I haven't said that about a Sony in a long long time.
Ken Ross is offline
post #94 of 334 Old 03-11-2011, 12:28 AM
YLK
YLK's Avatar
I wonder of the blue dot issue has been solved - any info on that?
http://product.pcpop.com/000308050/P...004441988.html
YLK is offline
post #95 of 334 Old 03-11-2011, 02:11 AM
djandrea's Avatar
iAUTO has set to dusk .... maybe that has darkened
look at the fountain
the 550 set image iauto to low lux
djandrea is offline
post #96 of 334 Old 03-11-2011, 02:14 AM
djandrea's Avatar
no
djandrea is offline
post #97 of 334 Old 03-11-2011, 02:21 AM
YLK
YLK's Avatar
I posted the photo because there were only two ways to avoid it in 550 - one was zooming in a bit, the other - using lens hood - and CX700 apparently comes with lens hood.
YLK is offline
post #98 of 334 Old 03-11-2011, 02:37 AM
djandrea's Avatar
i have a 560 without lens hood
raw 550
http://img858.imageshack.us/img858/7783/raw550.jpg
raw 560
http://img857.imageshack.us/img857/1351/mts560.jpg
but 560 twilight (more darker)
550 normal or low lux
djandrea is offline
post #99 of 334 Old 03-11-2011, 02:42 AM
djandrea's Avatar
http://www.multiupload.com/NVH9C3Z95E
here is the file "native" San Remo night at 20 mbps wmv magix exported, even more spectacular
djandrea is offline
post #100 of 334 Old 03-11-2011, 02:58 AM
YLK
YLK's Avatar
Blue dot appeared on 550 footage shot wide open in bright light, with sun at a certain angle.
YLK is offline
post #101 of 334 Old 03-11-2011, 04:56 AM
Ken Ross's Avatar
Liked: 6062
Good question. I didn't think the blue dot issue was that severe. Wasn't that just a form of lens flare?
Ken Ross is offline
post #102 of 334 Old 03-11-2011, 05:02 AM
Ken Ross's Avatar
Liked: 6062
no
Djandrea, do you have a video that shows the blue dot on the 560?
Also, since you have both the 550 & 560, have you found the 560 better in loe light? To my eyes the 560 low light pix is obviously sharper as are the videos I've seen, but you'd be the better judge on low light performance.
Ken Ross is offline
post #103 of 334 Old 03-11-2011, 05:19 AM
djandrea's Avatar
i have only 560 now the 560 is better also
in low light
djandrea is offline
post #104 of 334 Old 03-11-2011, 06:57 AM - Thread Starter
Steve Cebu's Avatar
I'm tempted to buy one today. If Amazon listed them as in stock, I just might pick up the Sony. But too many questions remain about it. I'm not worried about the $1,300 because I knew I would buy either the Sony or the Panny. I just wanted to see which one is the clear winner.
B&H Photo only has a 15 day return policy. Amazon will give me 30 days. My wife says I should buy both try them out and return the one I don't like.
The thing is I can't put any video on my ancient laptop. The Sandy Bridges recall pushed everything back a month at least. The revised chipsets just started shipping yesterday.
Argh! so frustrating because I really need it soon.
Steve Cebu is offline
post #105 of 334 Old 03-11-2011, 07:02 AM - Thread Starter
Steve Cebu's Avatar
So is Sony using WMV files instead of mts files? If this is a RAW file I believe it should be mts.
post #106 of 334 Old 03-11-2011, 07:05 AM - Thread Starter
Steve Cebu's Avatar
raw 550
raw 560
No question the 560 has crisper pics. I can see that everything is sharper in that pic. The low light performance comes at a cost of reduced sharpness.
post #107 of 334 Old 03-11-2011, 07:25 AM
dustindu4's Avatar
The lens hood looks crazy, check it out here
http://www.crutchfield.com/S-uJB2P8A...DR-CX700V.html
I wonder if you can buy it separate and if it would fit on the cx550
dustindu4 is offline
post #108 of 334 Old 03-11-2011, 07:57 AM
djandrea's Avatar
being a video editing can not have done mts files ....
djandrea is offline
post #109 of 334 Old 03-11-2011, 07:58 AM
djandrea's Avatar
I speak Arabic ?????? XD tell me no ... I said that the Sony 550 was set automatically in low lux
560 of the twilight !!!!!! twilight is less clear in the normal mode ... do you ..!!!!!!
djandrea is offline
post #110 of 334 Old 03-11-2011, 07:59 AM
djandrea's Avatar
djandrea is offline
post #111 of 334 Old 03-11-2011, 08:02 AM
Someone10101's Avatar
Originally Posted by dustindu4 View Post
Just a word of wisdom from us CX550 guys, Sonystyle will price match off any legit seller and beat it by a small percentage. That's what I did a year ago. Just call to order
Do they match the price only or S+H also since some places or maybe most places offer free S+H?
Thanks and thanks for the tip! Never knew Sony price match.
Someone10101 is offline
post #112 of 334 Old 03-11-2011, 08:29 AM - Thread Starter
Steve Cebu's Avatar
Then it really isn't a RAW file. Raw files are unedited, so you have lost your original video quality. I just downloaded it, took a while and will check it out later today on the 52" with the PS3.
post #113 of 334 Old 03-11-2011, 08:31 AM - Thread Starter
Steve Cebu's Avatar
Regardless, the pic was sharper on the 560. Look at the edges of the buildings in the background. The 550 is fuzzy whereas the 560 is crisp and sharp.
post #114 of 334 Old 03-11-2011, 08:46 AM
Dave Mack's Avatar
Vimeo is a good option for raw files.
Dave Mack is offline
post #115 of 334 Old 03-11-2011, 09:49 AM
Ken Ross's Avatar
Liked: 6062
raw 550
raw 560
Cleaner and sharper for the 560. Very nice.
Ken Ross is offline
post #116 of 334 Old 03-11-2011, 09:51 AM
Ken Ross's Avatar
Liked: 6062
I don't see any cost in low light performance with the 560. It's crisper and cleaner at the same time. Win win in my book.
Ken Ross is offline
post #117 of 334 Old 03-11-2011, 09:52 AM
Ken Ross's Avatar
Liked: 6062
I'm not crazy about the look of that lens hood. I think the one that's on the HF-G10 is much nicer looking. But hey, it's performance that counts in the end.
Ken Ross is offline
post #118 of 334 Old 03-11-2011, 10:03 AM
Ungermann's Avatar
Quoted: 516 Post(s)
Liked: 67
The hood is ugly as hell, they had to make a hole for the flash, as such the hood is not ideal to shade the lens from the light above. Eww. Bulky and ineffective. But nothing is perfect.
Ungermann is offline
post #119 of 334 Old 03-11-2011, 12:11 PM
dustindu4's Avatar
From what I remembered they price matched me and gave me a percentage of the difference which was around $35, so I got overnight shipping with that money. they don't free ship but who cares if you're saving $200
post #120 of 334 Old 03-11-2011, 12:18 PM
djandrea's Avatar
djandrea is offline
Reply Camcorders
