Sony HDR-CX110: HDFX footage onto Mac - AVS Forum | Home Theater Discussions And Reviews
Old 10-18-2011, 09:12 PM - Thread Starter
dustyjmoon's Avatar
I recorded some videos in HDFX before I knew that I wouldn't be able to put them on my MacBook Pro. Is there any way to change the files so that I can edit them in iMovie?
dusty
dustyjmoon is offline
Old 10-19-2011, 02:26 AM
sabatical's Avatar
What version of iMovie are you using? Apple has included AVCHD support with iMovie 11 - http://support.apple.com/kb/TS3634
sabatical is offline
Old 10-19-2011, 08:49 AM - Thread Starter
dustyjmoon's Avatar
oh cool. Thanks for the reply. I'm using iMovie 9 cuz I haven't upgraded to 10.6 yet. Maybe I'll just do that. Are there any other options like some obscure app that i can install just to get the movies on my computer drive?
Old 10-19-2011, 06:29 PM
sabatical's Avatar
You should be able to copy the files manually to your Mac without going through iMovie. I'm not familiar with iOS, but do you have a file manager program where you can browse the contents of your Sony's memory and copy the MTS files to your Mac?
Old 10-20-2011, 09:44 AM
Chevypower's Avatar
Liked: 40
You don't need a program to do that, you just open the camcorder up on the Finder, as if it were any other external hard drive. Just get Final Cut Pro X.
Chevypower is offline
