Video edit software for audio adjustments - AVS Forum | Home Theater Discussions And Reviews
Old 12-17-2011, 09:49 PM - Thread Starter
pauldknight's Avatar
Can anyone recommend any software which would allow me to:
(1) Fix unsychronized video and audio throughout a movie (when spoken words do not correspond with mouth movements).
(2) "Level" the sound volume throughout a movie (to avoid loud music that blasts me off the couch).
(3) Increase the voice volume, and reduce the music volume (so music does not drown out the speech).
I want to make these "edits" to full length movies which I have copied onto my HDD from my purchased DVDs (mostly "MP4" and "AVI"). So far, I have only Standard Definition movies on my HDD, but I plan to copy my Blu-ray discs in the future.
I use a PC with a Core i7-950 CPU, 6GB of RAM memory, a 128GB SSD for my Windows 7 Home Premium 64-bit OS and programs, and 2TB HDDs for data and backups. My video card is only a ASUS GeForce ENGTS450.
pauldknight is offline
Old 01-12-2012, 09:10 AM - Thread Starter
I have finally solved my problem #1; i.e. how to synchronize audio and video for movies played on my TV from my computer HDD. I upgraded from my old "WD TV Live Media Player (Generation 1)" to the new "WD TV Live Streaming Media Player (Generation 3)". This new equipment includes a menu adjustment to synchronize audio and video, and it works to fix my movies which are unsynchronized!
I never could find a software program to fix this in my video files, but the new hardware is perfect for my setup. I do not have an A/V Receiver (or surround sound speaker system), but the "WD TV Live Streaming Media Player (Generation 3)" can be used between a computer and the Receiver (of course, this would not be needed if the audio/video sync adjustment is included with your A/V Receiver).
Old 01-12-2012, 10:00 AM
bsprague's Avatar
Quoted: 505 Post(s)
Liked: 188
I am considering the same upgrade. I want to reduce the time between clips. If you put a collection of clips in a folder, select the folder and press play, what is the lag time between clips. My gen 1 players takes a few seconds.
I sent the same question to Western Digital and the odd answer was that I couldn't upgrade the firmware on the old one with the firmware of the new one.
bsprague is offline
Old 01-12-2012, 10:32 AM
Ungermann's Avatar
Quoted: 531 Post(s)
Liked: 69
Any NLE that has individual audio tracks and allows having multiple tracks can do what you want.
If A/V is sync'd when playing on a computer and is not sync'd when playing on a TV, then there is a problem with your setup. This is especially noticeable when audio and video take different paths, say you use a receiver or outboard scaler. My new BD player has a setting to set audio delay from 0 to 90 ms I believe.
Ungermann is offline
