Are any of these kit/wide angle lenses worth a damn? [TM700] - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-26-2011, 03:29 PM - Thread Starter
bob ross's Avatar
I didn't want to post this in the TM700 specific thread as I assume this question could be for any camera.
Looking around Amazon I'm seeing many different lenses I can use for my TM700, does anyone have experience with these? Some go for $20 others for $190.
I don't know about the quality of the stock "glass" on the TM700 but would one of these cheaper wide lenses noticeably degrade picture quality?
I guess basically I'm asking, what are your opinions on these?
$60 for the two
Official Panasonic for $186
Telephoto for $90
I don't know much about camcorder lenses, I can only assume there are not like Canon L series quality.... Would be nice to get a decent Wide-angle lens though...
Thanks for any suggestions as always!
Bob
bob ross is offline
post #2 of 7 Old 12-27-2011, 12:31 AM
bsprague's Avatar
Quoted: 510 Post(s)
Liked: 188
I bought the "cheap" official Panasonic lens: Panasonic VW-WE08H.
It is smaller and easier to carry but it has to be removed if you want to zoom much.
It works well for me.
Bill
bsprague is offline
post #3 of 7 Old 12-29-2011, 02:37 PM - Thread Starter
bob ross's Avatar
Bill
Hmmm $92.... You can't zoom much because of physical converter limitations?
bob ross is offline
post #4 of 7 Old 01-03-2012, 07:32 PM
Pepster returns's Avatar
That Vivatar wide angle adapter has very poor (artsy?) performance off centre.
I bought one, and didn't expect much.
I have since bought a SAMYANG 8mm F3.5 lens for my CANON 60D and I am very impressed with its performance. Very sharp edge to edge and with low CA.
Reviews here:
http://www.photozone.de/canon-eos/526-samyang8f35eos
http://www.lenstip.com/160.1-Lens_re..._Fish-eye.html
Sample still pictures here: http://photography-on-the.net/forum/...d.php?t=835464
Sample video here: (half this clip used the Samyang 8mm)
I also use PTLENS http://epaperpress.com/ptlens/ to 'de-fish' the stills (works great) but have not yet tried to 'de-fish' the video (should be able to do this in AE).
I have yet to see the adapters work well.
Pepster returns is offline
post #5 of 7 Old 01-04-2012, 07:12 AM
BrianSiano3's Avatar
I have the same lens. It's cheaper because it's not zoomable, which is easy to forget if you're using it in the field. And there is a noticeable amount of barrel distortion. But, if you want a lens _solely_ for wide shots-- where you're not zooming-- it works fine.
BrianSiano3 is offline
post #6 of 7 Old 01-04-2012, 08:09 AM
Ungermann's Avatar
Quoted: 535 Post(s)
Liked: 69
I already posted my video several times, I can do it again All shots in the video below have been made with the Raynox DCR 730 wide angle adapter attached to the camcorder.
http://www.youtube.com/watch?v=XOMDc7TdAzw
The adapter is 52mm, attached via 46mm-to-52mm step-up ring. It is fully zoom-through.
Ungermann is offline
post #7 of 7 Old 01-04-2012, 08:25 AM
bsprague's Avatar
Quoted: 510 Post(s)
Liked: 188
I'm not sure, but think it is optical limitations. The lens appears to be a simple piece of glass. Important to me is that it is more compact than any shown in the first post. A clever part is the way it mounts. If you think you are going to use it, you screw a ring on the front. Then, when you need a wider shot, the lens snaps quickly snaps into the ring. You can zoom to about 3x. After that it is a blur.
It comes with a two part plastic case that easily slips into a pocket. If you are being a busy walk around tourist, where you are taking it on and off a lot, you might want a clean plastic bag in your pocket for a temporary and dust free place to put it while you are shooting at high zoom settings.
Is it technically a good lens? I don't know but I like the picture quality on my 55 inch flat screen. It is useful in small rooms with people - like for a granddaughter birthday. It is useful in my son's 19 foot boot where, unless I learn to walk on water, I can't get far enough away to get two people in the shot. And, I enjoyed using it for street scenes in Italy.
Is $90 too much? Everything in photography is too much! Just think how much you save by not buying film and processing. That was too much!
Bill
bsprague is offline
Reply Camcorders
