Canon 5D motor noise. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-19-2012, 01:12 PM - Thread Starter
JamesP1701's Avatar
Quoted: 44 Post(s)
Hi all,
Love the image quality when using the mk 2 for filming. However, when I'm out and about I like to fill with image stabiliser on. Problem is, the noise of this is picked up by the onboard mic. I even bought the rode video mic pro but that too picks up he motor noise.
This for me, given how I like to use te camera, effectively renders it usefulness for filming. Has anyone got any suggestions? Very disappointed at the money.
JamesP1701 is offline
post #2 of 3 Old 02-19-2012, 02:31 PM
Blasst's Avatar
Quoted: 85 Post(s)
Liked: 80
James,
Have a look here, as there are many more owners of the 5D who can help you out.
http://photography-on-the.net/forum/....php?t=1115932
Blasst is offline
post #3 of 3 Old 02-19-2012, 02:37 PM
Quoted: 88 Post(s)
Liked: 32
You can try putting the Rode mic and 5D on a flash bracket; which can be used for hand-held or on a tripod:
It doesn't have to be put up top like that; there are different flash brackets that go off to the side and/or at a further distance away from the motor.
xfws is offline
Reply Camcorders
