HDC-TM700 files renaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-23-2012, 11:25 AM - Thread Starter
orfeas76's Avatar
Hello,
I just ruined the folder tree inside the SDcard.
Somebody please provide me that info...
AEWriter doesn't recognize the videos...
orfeas76 is offline
post #2 of 4 Old 02-24-2012, 10:41 AM
pjc3's Avatar
Look at page 127 of the manual ...it describes it there.
pjc3 is offline
post #3 of 4 Old 02-25-2012, 02:39 AM - Thread Starter
orfeas76's Avatar
I just corrected the folder tree but I have no luck, AEWriter doesn't recognize the source.
Isn't there any other program that can successfully rename files to their capture datecode??
orfeas76 is offline
post #4 of 4 Old 02-27-2012, 08:42 AM - Thread Starter
orfeas76's Avatar
edit:
With good response from Panasonic Netherlands (Thanks Ad) we found that PowerISO is causing this problem.
Just disable your virtual drives controlled by PowerISO and HD Writer AE works perfect
thanks Tinus
still There MUST be a simpler solution to rename files. AEwriter sucks...
orfeas76 is offline
Reply Camcorders
