Mistake: Upgrading Sony HX9V PMB Software to new Playmemories Home - AVS Forum | Home Theater Discussions And Reviews
post #1 of 36 Old 04-20-2012, 08:59 AM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Update:  December 2, 2012
I bought a new Sony camera that came with the PlayMemories Home built into the camera in October 2012.  I let it install when i first plugged in the camera.  It works well with all the existing photos and videos from the HX9V as well as the new ones from the RX100. I do not know what went wrong on the first try last April.
From April, 2012:
Lately, starting the Sony PMB (Picture Motion Browser) software has brought popups to upgrade to to "Playmemories Home". I gave in and did it.
It installed OK. But when I tried to "Manipulate/Edit" or press the "Edit" button it said my videos and photos were the wrong format.
With my software now screwed up, I did a little reading. Apparently there are four parts to "Playmemories". One for the cloud, one for your Sony TV, one for your computer and one for your PS3. There did not appear to be any extra editing features.
I 'fixed' it by uninstalling Playmemories, re-installing PMB, then updating it to version 5.8.02.
PMB is important if you want to trim and combine clips while preserving the original 1080p quality that a lot of editors don't do when they render.
I suggest you don't upgrade.
Bill
bsprague is offline
post #2 of 36 Old 05-12-2012, 07:46 PM
jessefebe's Avatar
I had the same problem, and I'm going back to PMB. I was really dissapointed.
jessefebe is offline
post #3 of 36 Old 05-17-2012, 08:58 PM
Shield's Avatar
Tips like this are greatly appreciated; I almost upgraded my PMB the other day - glad I didn't!
Shield is offline
post #4 of 36 Old 06-03-2012, 09:19 PM
BeagleEyes's Avatar
I have updated and it seems to be working fine for me. I did get that message at first but then I saw in the top right corner a menu that gives 4 options to select, edit picture, trim video, combine videos, or save frame. Once I selected trim video first and then edit, it opened a new small window to trim my video. I closed that and restarted edit and selected combine videos, took one video and added it twice, hit edit, and it opened a new small window again, I chose combine and it combined them with no problem.
I would give it another try.
BeagleEyes is offline
post #5 of 36 Old 06-04-2012, 07:13 AM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Originally Posted by BeagleEyes View Post
....I would give it another try.
Thanks for offering the suggestions, but no thank you.
Unless I'm missing something, the reasons to upgrade do not include editing features. Sony's "Play Memories" is about cloud storage, Sony TV viewing and PS3 playback. The editing features provided in PMB are appropriate for the Sony camera I have. Unless I want to use Sony's version of the cloud, there is no reason to change.
Bill
bsprague is offline
post #6 of 36 Old 06-04-2012, 08:28 PM
BeagleEyes's Avatar
Bill
I can understand that you would be hesitant after the issue you experienced but I would reconsider. All new Sony cameras are coming with Play Memories software which is PMB's replacement. My experience with PMB has been had with multiple problems (I won't go into that) but I think Sony finally got it right with Play Memories (besides the little issue described in the first post). The software has been completely redesigned to work better. I don't use cloud, Sony TV or PS3 playback. But what I do use it for (playing and editing) does seem to work much better.
It wouldn't hurt to give it another try (actually give it a try because you never really got to try it). And now you know you can always go back.
post #7 of 36 Old 07-26-2012, 07:50 AM
ldfrmc's Avatar
I have three Sony camcorders (MHS-CM5, HDR-TG1, HDR-HC9) and use Picture Motion Browser (PMB) 5.8.
I've finally got PMB to work - recognize all three camcorders, their clips (MP4, AVCHD and MPEG2 by their extensions .mp4, .m2ts, .m2t), play and edit each type of clip smoothly and maintain all the labels and comments I have entered about my clips. It is my primary catalog for over 6,000 video clips.
I looked at a new Sony camcorder (HDR-GW77, waterproof, dust proof) but decided not to buy because ONLY PlayMemories will work with that SONY camcorder.
*** Sony cannot tell me which formats from which of my existing SONY camcorders will work with PlayMemories. *** PlayMemories cannot be loaded on a computer without wiping out PMB and "updating" information from my existing catalog in PMB. ***
The last time I updated PMB to 5.8, that process WIPED OUT ALL OF MY CLIP COMMENTS and LABELS and my clips developed problems playing smoothly. I do not want to spend weeks, re-entering all that information again or seeing stuttering/skipping video playback for clips from my existing camcorders. SONY says there is no way to backup or extract the data in PMB or even PlayMemories software catalogs (file name, date and time captured, date modified, camcorder used, clip duration, resolution, comments and labels).
I've looked at several other catalog software programs - none support all three camcorders (or the potential fourth) SONY camcorder.
I did not mind SONY's monopoly of PMB compatibility only with their camcorders, but I do not want to buy a SONY camcorder that REQUIRES and ONLY WORKS with PlayMemories and it is unknown how, or if, it will work with my other SONY camcorders and clips.
ldfrmc is offline
post #8 of 36 Old 07-26-2012, 08:45 AM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
I see two potential options.
First, buy the new camera (and that one appears to be a terrific choice) from a place with a good return policy. Set a Windows restore point and install the new software. If it works, fine. If it does not work, restore the computer back to where you started and send the camera back.
Second, before you buy the camera, study up on another catalog program. I have been enjoying the learning of Premier Elements 10 because it opens so many editing options. It comes with Adobe Organizer. I've ignored the Organizer because I used PMB. The last couple of seeks, I've forced myself to learn Organizer. I'm beginning to think it is much better at keeping track of what and where my material is. You can download PE10 and use it for a month for free. After that you have to spend about $65. In other words, I'm suggesting you consider abandoning PMB for the sake of something that won't stop you from progress. Others do it, especially Mac users.
Good luck.
Bill
bsprague is offline
post #9 of 36 Old 07-26-2012, 09:12 AM
markr041's Avatar
Quoted: 937 Post(s)
Liked: 296
I have a Sony NEX-5N, a Sony Hx9v, a Sony HDR-TD10, and the Sony HDR GW77v. I "upgraded' from PMB to Play Memories. The new software plays and *edit* clips from *all* four cameras without any glitches. I did not lose any information when I upgraded. All the videos I have posted on this and other forums from all of these cameras have been edited and put together using PlayMemories.
It is one the few editors that allows editing108060p videos without any loss of quality, and is therefore also lightening quick.
The software understands 3D, so can take advantage of any 3D features of any Sony camera. It understands GPS, so can take advantage of any Sony camera with GPS (mapping). But the key point is the lossless video editing of 108060p videos.
I have also used the software on netbook computers - it can edit fine.
markr041 is offline
post #10 of 36 Old 07-26-2012, 01:05 PM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
I like PMB too. But the upgrade to Play Memories did not work. Perhaps the upgrade would work better now.
For now, I continue to use PMB and am learning what I can add to my projects by using Adobe Premier Elements 10 -- where I think I have figured out how to make a lossless end product.
Bill
bsprague is offline
post #11 of 36 Old 08-13-2012, 08:06 AM
Dwaelf Wanderer's Avatar
Having spent months tagging my photos, I was not best pleased to find that after installing playmemories the tags had all been removed. Furthermore, it seems to be no longer possible to move the tags to rearrange them after they have been created. I have photos from my family spanning over a century and now I have to retag the whole lot. So much for being able to play memories.
Why is it that when companies release 'improved' software with new features, they fail to maintain the features of the old software which users have obviously used and presumably want to keep? As for the cloud storage, it wouldn't store even a tenth of my collection, so it is literally just a waste of space.
I've just removed the software and reinstalled PMB. I do have other editing software I can use if I need to, but I prefer PMB. Possibly not for much longer, though, if this is what they consider to be the way forward!
Dwaelf Wanderer is offline
post #12 of 36 Old 11-25-2012, 01:35 AM
urednik's Avatar
I make the some mystake.
In Playmemories I miss option "search".
Basic have search option, but it not search by name of photo.
I couldn't belive that, contact Sony .. after 1 week I reinstall PMB.
SW that couldn't find picture by name is STUPID .....
By the other hand I lowe my camera na now I miss my video recordings.... But I can find my pictures by name .......
urednik is offline
post #13 of 36 Old 11-25-2012, 08:19 AM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Bill
I got a new and different Sony camera and Play Memories was built in to it. When I plugged in the new camera Play Memories installed and is working fine now. I also upgraded my Premier Elements to version 11 because it has "official" support of 1080p60 video.
Bill
bsprague is offline
post #14 of 36 Old 11-26-2012, 04:34 AM
Railfan's Avatar
The news that if I get the GW77, it will automatically come with the new Sony browser software (Playmemories) and compromise my PMB files, making them less useable, is not something that I want to hear. I have hundreds (over a thousand easily) of video files and hundreds of picture files with PMB. While some of them are in my NLE library, I would like to know if there is another worthwhile place to save all these valuable files. Could I use a dedicated external drive, or would it too be compromised by the new Playmemories program?
By the way, these video files that I have are from older camcorders; ie a Sony FX7, and a Sony SR11. While the videos from the FX7 are backed on tape, the SR11, of course is not.
Question: If the PMB files are compromised, are they still completely usable within an NLE library?
Mike
Railfan is offline
post #15 of 36 Old 11-26-2012, 09:10 AM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Mike
Mike,
If you like what you are using, don't install the new Sony software. It's optional.
Bill
bsprague is offline
post #16 of 36 Old 11-26-2012, 09:19 AM
Railfan's Avatar
Mike,
Bill
It has been awhile since I have had a new camcorder. If I don't have to download/install Playmemories when I get the GW77, then that would put it back at no. 1 on my Christmas list.
Thanks Bill.
Mike
Railfan is offline
post #17 of 36 Old 11-26-2012, 11:02 AM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Thanks Bill.
Mike
Of course you don't have to install software. If you have a Mac you can't! My new Sony P&S has the Playmemories Home in it. My older Sony P&S came with a DVD. I don't know how Sony delivers software with the GW77. If it is in the camera, it may ask you to install it when you plug the camera into you computer. For me, it is easier to move the files by plugging the SD card into the computer. Then any software will move the files, including PMB or PMH . Don't let software get in the way of your camera choice!
Bill
bsprague is offline
post #18 of 36 Old 11-26-2012, 11:36 AM
Railfan's Avatar
Sometimes, I panick before I give myself time to think. Other times I just prove to myself that I am not too bright.
As long as there is a way to not use the new software, and the GW77 will work just fine with the old PMB, then I will be a happy camper.
Mike(Railfan)
Railfan is offline
post #19 of 36 Old 12-02-2012, 04:15 AM
UKDubey's Avatar
Whatever happened to Mapview ? When I 'upgraded' to Playmemories I lost use of Mapview ? And when I tried connecting my DSC HX100V , for the new version of Playmemories which gives Mapview, I was told I am not eligible for the software . I am deleting Playmemories and going back to PMB. Would appreciate comments / advice .
UKDubey is offline
post #20 of 36 Old 12-02-2012, 07:05 AM
markr041's Avatar
Quoted: 937 Post(s)
Liked: 296
I have Playmemories Home and it has Mapview.
Map View.jpg 658k .jpg file
markr041 is offline
post #21 of 36 Old 12-02-2012, 09:34 AM
UKDubey's Avatar
Dear Mr. Markr041, can you elaborate on as to what is the hardware ( camera ) you are using ? I will explain here my efforts in trying to get Mapview in Playmemories Home.
In PMB, the PMB Launcher gives the Mapview / Calender view option. In Playmemories, or at least the version I had there was no corresponding 'launcher'. I. I have spent hours googling to get Mapview in Playmemories, and the only answer I get that there is a paid version of Playmemories ( which I do not want ) , However, I also learnt that there is a free version , but that this free version is available for ONLY the hardware launched during 2012 . This is pointing towards DSC HX 200v ( my guess ). When I , with my humble DSC HX 100v - purchased in Oct 2011, tried to use the software - I got a response that my hardware is not eligible to download the Mapview version.
Can somebody at Sony clarify / explain why this restriction was imposed ?
I have now removed Playmemories Home , reinstalled PMB version 5 from the CD that came with the camera ( luckily I was holding on to it ) and am happily using Mapview .
I fell in love with the DSC HX 100v for a number of reasons, and one of them was the facility of seeing my geo-tagged photos on a satellite view of the earth. I have been using this feature for the last 1 year during my travels - Dubai . Toronto and Jinan in China , to pinpoint the locations I visited. This helps me visualise my locations on the map - as many times - we travel courtesy the local hosts - and are unaware of where we went .
UKDubey is offline
post #22 of 36 Old 12-02-2012, 10:03 AM
markr041's Avatar
Quoted: 937 Post(s)
Liked: 296
Maybe you don't know how to use the new software. PlayMemories Home is a free upgrade for *anyone* who has PMB. It does not matter what camera you have, PlayMemories replaces PMB.
PlayMemories works differently than PMB, which is why you may have missed the "launcher." You should check on this forum first before calling Sony or removing software, and we can help you use your new software.
In PlayMemories, you select a clip that has GPS coordinates, then you click an icon on the bottom left of the view panel. That puts the clip on a map. It works. My picture shows you it works. It works with my old Hx9v and my new GW77V.
markr041 is offline
post #23 of 36 Old 12-02-2012, 10:13 AM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
"you select a clip that has GPS coordinates", or a group of video clips and photos.
Works with my "old" HX9V but not with my "new" RX100 for lack of GPS data.
I started this thread. I tried the new sofware and something messed up. When I got a "new" Sony that came with the "new" software, I tried again and it works fine.
Bill
bsprague is offline
post #24 of 36 Old 12-02-2012, 03:37 PM
Joe Trancoli's Avatar
Call sony direct, They are always helpful when I have questions. I also use Picasa for my sony pics. its free. http://picasa.google.com/
Joe Trancoli is offline
post #25 of 36 Old 12-02-2012, 05:46 PM
RFEngineer's Avatar
I keep downloading the new versions of PMH whenever they come out, like the 2.0 did a couple days ago.
Each time I install it I find the same missing feature that keeps me going back to PMB every time.
I like to geotag my photos, and not all of my cameras have integrated GPS receivers and even the ones that do won't get a lock if you are in a building, so I use PMB's excellent mapping "search" text-box at the bottom of the map-view to input a street address, or the name of the school, park, museum, etc. to find the exact location for tagging those photos.
With probably (in my experience) 95-99% proper resolution of that location as coordinates from that search, it makes it simple to tag the photos with the correct location.
So far, every single version (2.0 included) of PMH is absent this search text-box in the map-view. No clue why.
Probably a license thing with Google maybe?
Don't know, but without that key feature it's always uninstall and go right back to PMB 5.8.x again - like I'm doing right now.
RFEngineer is offline
post #26 of 36 Old 12-14-2012, 10:02 PM
alrprairie's Avatar
Newbie here.
I was looking to see if Playmemories software would allow me to add music to video's, since PMB does not. I am glad I read this thread about 'upgrading' to Playmemories. Right now, I am not planning on 'upgrading'.
Any suggestions on overlaying video's audio track with music, etc?
alrprairie is offline
post #27 of 36 Old 12-15-2012, 08:32 AM - Thread Starter
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Originally Posted by alrprairie View Post
Newbie here.
Welcome!
I started this topic 8 months ago. Since then, I have successfully upgraded to PMH and, recently to 2.0. I use it as the first step to move video and photos to my computer and keep track of everything. Next, I use it to quickly review, get rid of the duds and maybe some quick trimming.
When I want more than PMH offers, I switch to my favorite NLE, Adobe Premier Elements 11. Among its many features, it will let me overlay and control an audio track. In fact it allows up to 99 tracks!
Another popular NLE on this forum is Sony's Vegas. Like Adobe, Sony makes multiple versions, including some that are "consumer priced" .
bsprague is offline
post #28 of 36 Old 12-23-2012, 03:19 PM
glad2badad's Avatar
I just upgraded to PlayMemories from PMB and now my custom "labels" that I had for tagging / searching / organizing my photos in PMB are missing. The photos, when displayed in PlayMemories, show evidence of tags but they've been renamed to a generic "New label (#).
Is there a way to get my prior labels back or do I just need to go back to prior system restore point to make everything right (using PMB)?
glad2badad is offline
post #29 of 36 Old 12-24-2012, 01:55 PM
ldfrmc's Avatar
Newbie here.
If you use a PC (Windows) you should have a free copy of Windows Movie Maker. That fee software program will add an audio (music) clip to a video clip and allow trimming/moving both.
Microsoft's website has the downloads for all "flavors" (operating system versions of Movie Maker)
http://windows.microsoft.com/en-US/windows/get-movie-maker-download
ldfrmc is offline
post #30 of 36 Old 01-06-2013, 12:18 AM
Steve McD's Avatar
There's a lot of misinformation about the Play Memories Home Program in this thread, that is mainly a result of people not taking the time to learn how to use it. In just the last few days, it has been upgraded to version 2.0. It looks very different and has more features. Disregard anything that has been said about PMH before this and download the 2.0 version, before making up your mind about it. For one thing, the ability to record Data DVDs has been restored. I find it to have the easiest and best quality for re-sizing photos, if you put the quality level on the highest option of 6.
Steve McD is offline
Reply Camcorders
