Joining .MTS files without it glitching out - AVS Forum | Home Theater Discussions And Reviews
Old 04-28-2012, 09:08 PM - Thread Starter
Danboyland's Avatar
I'm trying to join multiple .MTS files without having to re-encode. I've used a few different tools including tsMuxeR. The result is the same for all of them. The video goes black at 1:06 and the image flickers on and off. Sometimes Windows Media Player crashes.
Is there anything I can do to fix this?
Danboyland is offline
Old 05-03-2012, 09:04 PM
scooby_scrappy's Avatar
You should look at Aunsoft FinalMate.
The software allows you to take MTS files and append them together without encoding. The software allows you to convert to a different format also.
scooby_scrappy is offline
