Veho Muvi HD10: Review - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-15-2012, 07:38 AM - Thread Starter
gary miller's Avatar
The full product name is: Veho VCC-005 Muvi HD10
I had posted some comments on another thread recently, which I'll expand upon. I thought it might be a good idea to bring this unusual and relatively unknown camcorder to the attention of fellow enthusiasts at AVS. I don't think the Muvi HD10 has generated much discussion here in the past. Also, with the growing proliferation of HD video enabled phones, the Muvi still performs in ways that are not addressed by any current multipurpose phone.
Veho is a small electronics company located in the UK. The Muvi is one of two camcorder lines, and I suspect the original, standard definition micro Muvi was originally conceived for the surveillance market. (Veho still markets the standard definition line as the VCC-003, and VCC-004).
The Muvi HD10 is, for all intents and purposes, marketed as a cross between a traditional pocket camcorder (albeit a short lived tradition) and the surprisingly popular GoPro. (I have not had any hands-on experience with the GoPro, so I can't make any comparative comments about quality). The shape and form factor, however, between the GoPro and Muvi completely part company. The Muvi has a small 1.5 inch viewfinder. The GoPro has none (I believe a clip-on viewfinder is available as an accessory). The GoPro is waterproof. The Muvi offers a waterproof shell as an accessory. The Muvi is housed in a rubberized metal black box that's a bit smaller than a pack of cigarettes. The viewfinder-menu side of the cam is pleasantly sleek looking.
Veho offers several package variations of the Muvi-HD10, with a mix n' match assortment of clips, mounts, straps, velcro, cables and chargers. It can be attached to a helmet, mounted on a bike, in a vehicle, or on your body. I purchased the promotional "Gumball 3000" edition. (Actually, I wound up buying two). I have no interest whatsoever in that road rally, but I thought (and still think) the accessory assortment in that box represents the best value. I'm not too enamored with the cartoonish Gumball logo that's plastered on the lens side of the cam, but the black faceplate is still pretty inconspicuous. The Gumball Edition and the unadorned HD10 are functionally identical.
There are few, if any, professional reviews of the Muvi. The majority of consumer and Youtube comments focus on this camcorders considerable action-cam capabilities. However, the Muvi's "hands-free" potential is what I found most intriguing, as the usual routine of pointing and shooting can get pretty tiresome. Standing still, and using the included body clip, I was able to record long, uninterrupted segments of a soccer game with nearly the same stability as a tripod.
I would suggest attaching the cam to a taut belt, or use the included strap, as it's important to keep the lens perpendicular, and not dangling toward the ground. It took some experimentation, and rigging, to find the right position. I alternate now between my upper arm (which invites some quizzical looks from passers-by) and my belt, where the cam is less obtrusive. While I can't quite pan as smoothly as a tripod by turning, it's a pleasure to watch events, without peering through a viewfinder, and still record very stable footage at the same time. (The Muvi can also be used like a standard point-and-shoot pocket camcorder using the 1.5" screen).
The wide angle lens captures everything in my field of vision, and then some. There are some trade-offs with this Cinemascope style lens, not unlike those ultra widescreen films of the 1950's: There is some fishbowl geometric distortion, but I found this effect much less distracting than I feared. Also, objects are a bit softer on the edges of the frame, but still quite sharp toward the center. Despite those caveats, I find the ultra widescreen image produced by this little cam to be absolutely thrilling at times. I picked up action in the image that I hadn't noticed in real time.
The angle is a bit wider in the 720p60fps mode. Personally, despite the huge file size, I prefer the sharpness of the 1080P/30fps mode for most athletic events, but very fast moving activity (motor sports, etc.) appears unquestionably smoother in the 720/60fps mode.
Although the record button is smartly placed on the side corner of the camera, the large button remote control worked reliably, and proved much less cumbersome than stopping and starting from the camera. In fact, I'd rate the remote control as a major feature enhancement for the Muvi.
The Muvi, like most pocket camcorders, employs a fixed focus lens.
The 1080p quality is great in daylight, and more satisfying in some respects, than my 6 year old standard definition prosumer Canon GL2. (It's amazing how quickly and inexpensively HD technology has flowed through the market pipeline). Low light performance is serviceable, but don't expect miracles. (The Muvi is probably not the best choice of cams for night time birthday parties). The audio is OK, but a little thin. The zoom feature is only available in 720P mode, but digital zoom capability (as opposed to optical zoom) is not a compelling feature in my book.
In fact, I wish the zoom could be disengaged altogether. The touchscreen buttons on the Muvi are extremely sensitive, and it's easy to engage the zoom function accidentally. (This happened once, when I carelessly inserted the cam back onto the body clip). I'm thankful it's not an option in 1080P.
Like most pocket camcorders, the Muvi's usefulness as a still camera is limited, at best. (I also find the lens distortions more bothersome when viewing still captures). From my perspective, the Muvi devotes too much menu and feature space to camera mode. Instead, I wish there was more attention paid to streamlining the camcorder ergonomics instead. Overall, the Muvi falls short in user-friendliness for the following reasons:
A)The deletion of files is way more complicated than it needs to be.
B)It's also easy to confuse the voice activated (VOX) switch for the power switch. I did this several times until I became comfortably familiar with the little camcorder, and even then I covered it with black tape so I couldn't confuse it with the on-off switch . (Since I was in a noisy location, the cam would not stop recording with the VOX turned on). The VOX control is a very useful surveillance feature, but it doesn't belong on the side of the camera as a hard switch.
C)The Muvi uses the micro SD format, which can be a little finicky to load and remove. I much prefer the standard sized card.
D)The playback functionality through the viewfinder is clumsy and confusing, (the sub-menu for playback is called "record"..go figure) as are the microscopic icons in respect to battery life and data card space. The terse manual is not much help.
Still, my biggest gripe also applies to a majority of pocket camcorders: If you're shooting footage of any event, you should never have to worry about battery power. While the Muvi's battery life is generous,(Veho claims three hours of continuous recording), nothing is more frustrating than a dead, integrated (not-removable) battery. (What's more, lithium ion batteries have a fairly long, but finite lifespan. When the battery is toast, you can toss the camcorder).
While the MuviHD10 is not the best thought-out pocket camcorder on the market (I also own a Kodak Playsport ZX5, which is far more intuitive) it is undeniably unique as a recorder with real hands-free capability, and the benefits of that feature should not be underestimated: Passive, hands-free shooting means subjects are less likely to duck, dodge, wave, or mug for the camera. You'll be able to record long, uninterrupted segments without the boredom or concentration of staring at a viewfinder while trying to keep your arm and hand as steady as possible.
Overall, despite some design flaws, the engineers at Veho came up with a particularly useful, and versatile camcorder. I really hope Veho continues to produce and perfect the Muvi HD line. Right now, it's truly one-of-a-kind.
gary miller is offline
post #2 of 11 Old 06-17-2012, 03:25 AM
brunerww's Avatar
Quoted: 58 Post(s)
Liked: 37
Thanks for the writeup, Gary. Sounds like a cool device.
I'm still waiting for an affordable pocket/wearable camcorder with an external mic jack. I just bought a couple of Alesis VideoTracks on clearance - but I would have paid the $149 that the Veho Muvi HD10 costs to get one with an external mic (but I'm not going to pay the $300 for a Zoom Q3HD or $450 for an old Kodak Zi-8).
Cheers,
Bill
Hybrid Camera Revolution
brunerww is offline
post #3 of 11 Old 06-17-2012, 06:51 AM - Thread Starter
That's a very good point. Audio is a weak link in these pocket camcorders (either too muffled or too tinny) but an external mic jack seems like an easy add-on.
post #4 of 11 Old 06-19-2012, 08:55 AM
nameform's Avatar
Nice review, can you post some video samples?
nameform is offline
post #5 of 11 Old 06-25-2012, 06:23 AM - Thread Starter
This is lower Manhattan (Delancy Street) around 7:30 on Sunday morning. I was "wearing" two Muvi HD10's attached to my belt. The lenses were about 6" apart. One cam was set to 1080p and the other to 720P. Both clips were recorded simultaneously. (I did not have the remotes handy, or edit the files, so you'll see my hand obstruct the lens momentarily).
I was a little careless rigging the 1080P cam to my belt, and the bottom of the unit was not perfectly parallel to the ground. Consequently, the perspective is tilted by 15 or 20 degrees.
Note that the fishbowl distortion is more pronounced in 720P, but it's clearly a wider angle as well. (I'll try to get clarification from Veho about this).
Also, if you're not a regular Youtuber, be advised you might have to use the icon adjustment for viewing at 720p and 1080p respectively. While the Youtube conversion is pretty damn good, it's not as good as the actual file, as the processing adds some artifacts of it's own.
http://www.youtube.com/watch?v=YuhcaS5Cap8
http://www.youtube.com/watch?v=RoOBkaoekao
Also, here's a look at the mounting accessories found in the "Gumball Edition" box:
599
post #6 of 11 Old 06-30-2012, 04:35 AM - Thread Starter
I edited and revised my earlier comments about the Muvi field of view. Apparently, I misinterpreted an email correspondence from a Veho technician that read:.. on the full HD models you can vary the angle between 160 and 120 degrees. On our standard resolution models, the field of view is set to the default 72 degrees. I hope this helps.
Judging by my own clips, the angle is wider in 720P mode, but the distortions are more pronounced. 1080P is still impressively wide though.
Here are a few other clip samples at a horse riding facility, with the Muvi HD10 again clipped to my belt:
Youtube link: http://www.youtube.com/watch?v=6K3edeOvZMA
Youtube link: http://www.youtube.com/watch?v=2mJs6g1Op4s
For the next clip, I am standing in the same spot, but switched back to 1080P (Note the detail and splendor of horse flop in full 1080P)
Youtube link: http://www.youtube.com/watch?v=Oz8xm4YvErQ
post #7 of 11 Old 10-10-2012, 02:13 PM
clif22's Avatar
Hiya
I have had my HD10 for about a week and bought it for skiing and snowboarding and skateboarding and bikeriding and haven't really had a good chance to try it out yet in daylight. It seems quite good and the quality rivals the GoPro but much nicer to have a little monitor. I also bought a 32gb sd card so capture a bit more when out and about. I rigged up a chest harness using an elasticated luggage strap and the arm strap they give you in the box....I also bought the waterproof case which has an arm strap too
One upset though... I've noticed the record button rattles and sounds a bit cheap.
I bought a mini hdmi to hdmi cable but this doesn't seem to work on either of my hdmi tvs I have in the house...does anyone have any experience of this or know the exact spec of the lead required? Shame it's not included in the box really as the leads don't cost a lot.
Clif (UK)
clif22 is offline
post #8 of 11 Old 11-24-2012, 03:12 PM
Ajames456's Avatar
I have recently bought a Vehu Muvi HD10. It is marketed as having more features than the Gopro (I also have a Gopro 2), but in my opinion falls miles short of the "outdoor capabilities" of the Gopro.
I have used both of these cameras for recording white water kayaking.
The Gopro has been perfect in every way even though it does not have screen.
The problems that I have encountered with the the Muvi:
The curved helmet mount allows the camera to "rattle", where the "securing rails" appear to have been splayed during the curving process.
The entry slot for the Micro SD card is way too wide, allowing the card to be slotted in alongside the connector (lots of "fun" had getting it back out).
When the video record is stopped and the unit goes into standby, restarting the unit and trying to get into recording while in the waterproof case is very "hit and miss", the unit wakes up and almost immediately goes into a menu, which is impossible to get out of, unless you either take it out of the waterproof case or you are looking at the screen and react immediately to it waking up and push the button again.
The fitting for the waterproof housing is totally inadequate for any sort of outdoor activity, since the slightest g-force, splashing of water, quick movement of the head etc will undo the fitting.
The upright design of the unit makes it more vunerable to damage and also more prone to moving.
The adhesive mounts are very poor, even though they appear to be made of the same material as the Gopro uses. Both my curved helmet mount ant flat mount fell off with very little provocation. in both cases they were stuck onto clean, dry and degreased surfaces (using the same method as I use with the Gopro mounts.
Muvi has a long way to go to get anywhere near the Gopro.
Ajames456 is offline
post #9 of 11 Old 12-26-2012, 01:13 PM
jonford's Avatar
I bought tge muvi gumball 3000 this time last yr to take skiing. I can honestly say its the best ski accessory ive ever bought. Its v easy to use and supplies great quality footage. The remote is a fantastic extra and ideal when skiing. I bought the waterproof case which is great. Buttons feel fine. Menu is a bif fiddly but does the job. The screen is a great bonus. I recently watched a revuew companies reviews and they preferred it over the go pro. Most go pro videos on youtube r by professional companies (eg redbull) where they use editing software to modify the quality of footage so always look better thanother films. Here is an undoctored film I did on a ski hol https://www.youtube.com/watch?v=T2FI1rVkd2M&feature=youtube_gdata_player
jonford is offline
post #10 of 11 Old 01-20-2013, 09:51 AM - Thread Starter
Great looking video, Jon! Did you shoot in 720 or 1080P? I'm a little puzzled though why the video was scaled down by Youtube. I was able to upload my video samples above in their correct resolution without a problem (some quality is admittedly still lost to Youtube processing).
I was going to respond to AJames comments by suggesting that GoPro is probably better suited for first person action, but the Muvi is ideal for use by a spectator. Your impressive video punches some holes in that proposition. I would still say that the GoPro and Muvi are somewhat different animals with their own set of pluses and drawbacks.
I agree with you about the remote too. It's great for grabbing action on the fly.
post #11 of 11 Old 09-29-2014, 02:26 PM
Liked: 0
Veho Muvi "blank" files
Been having some problems with my files. Some of them are fine, but in some others I run the file (after saying "converting") but all it shows is a blank screen I have a MacBook Pro and use Quick Time Player.
claud.m is offline
Reply Camcorders
