Why shoot in HD if you have to convert? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-28-2012, 12:02 AM - Thread Starter
quixoticquest's Avatar
Maybe there's already a thread for this, but I've been brooding over this issue since purchasing my new cx570. Like most amateurs, I quickly realized my computer is not powerful enough to handle Sony's AVCHD files, for both viewing and editing. Naturally I figured out how to convert the files into wmv or avi (which of the two is best, by the way?). The switch naturally reduces resolution quailty I think, so I'm wondering about the concept of just shooting in standard mode (HQ 50i) until I have more harddrive space. What would I lose as a struggling videographer in regards to quality. I know shooting in HQ I will lose the widescreen -- does that mean my video will look unproportioned on a television screen?
quixoticquest is offline
post #2 of 5 Old 06-28-2012, 02:38 AM
Flybear's Avatar
If you are using a Windows PC, maybe WMV is better for editing in Windows Movie Maker, But if you are using a Mac, I guess MP4 format would be better. I don't know what do you use to convert your AVCHD files, Handbrake or anything else? I always use enolsoft video converter to encode videos, it supports HD quality output, maybe you can have a try. Just my personal experience.
Flybear is offline
post #3 of 5 Old 06-28-2012, 04:16 AM - Thread Starter
I'm using wondershare to convert my videos. Seems good so far. Fast.
What do you mean that ensoft supports 'hd quality output', that it leaves better quality after converting from the avchd file?
post #4 of 5 Old 06-28-2012, 06:06 AM
seggers's Avatar
Quoted: 99 Post(s)
Liked: 52
I would continue to shoot in full HD and buy a $100 TB external USB drive to keep stuff on.
Once I have that in place, it's time to save some pennies and buy a better PC, by either buying the parts, or buying it in one go.
Go for the biggest CPU and memory combo you can afford.
But always shoot in full HD> It gives you more options down the line...
Seggers
Vizio M80-C3, Denon X6300H, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, PC DX12 sub, Def Tech A60 Atmos tops, the internet, an ASUS ChromeBox running Kodi, a TiVo Series 3 and a Philips BDP7501 UHD . There's also a Wii, but we don't talk about that...
seggers is online now
post #5 of 5 Old 07-07-2012, 07:33 AM
Pepster returns's Avatar
Your TV is HD, isn't it ? - and you want your footage to look good on your TV, no ?
ergo, shoot in HS, & always keep your original files. Drives are dirt cheap now.
Pepster returns is offline
Reply Camcorders
