International Space Station Flyby Video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-28-2012, 09:11 AM - Thread Starter
ronlhodges's Avatar
The ISS did a Flyby over my location last night so decided to try video on it . This is best seen at Full Screen and a darkened room so you can see at entry it passes over Mars then as it passes over the moon you can see a star closest to the moon called Spica and just above Spica is Saturn . Then it heads off to the south towards the constellation Scorpio but this is not seen very well at all as it disappears back into earths shadow . If your room is dark enough you may see a tree in the lower left corner at the end of the video . Hope you enjoy the Video .
http://www.youtube.com/watch?v=qiNUB_EpeR0
ronlhodges is offline
post #2 of 5 Old 06-28-2012, 09:28 AM
bsprague's Avatar
Quoted: 495 Post(s)
Liked: 180
Nice!
What are you using for editing software? It appears it works well for you.
Bill
bsprague is online now
post #3 of 5 Old 06-28-2012, 09:49 AM - Thread Starter
ronlhodges's Avatar
Originally Posted by bsprague View Post
Nice!
Bill
Thanks Bill , i'm using Adobe Premiere Elements 10 . Someone here told me about and it is well worth the $$ and alot cheaper than the $800.00 for the Cs6 Premiere !
post #4 of 5 Old 06-28-2012, 10:01 AM
bsprague's Avatar
Quoted: 495 Post(s)
Liked: 180
That might have been me! I confess to being a PE 10 fanboy and to posting recommendations for it many times.
Bill
post #5 of 5 Old 06-28-2012, 11:15 AM - Thread Starter
ronlhodges's Avatar
Bill
Very likely it was Bill cause you have commented to my post more than anyone here . Thanks for the tips on PE 10 ! It's well worth it !
Reply Camcorders
