Looking for "Easy-to-use" home video editing software for my Panasonic HDC-SD800 Camcorder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-01-2012, 11:16 PM - Thread Starter
seinfeld1104's Avatar
I used this forum last year to choose my Panasonic HDC-SD800 camcorder. Love the unit and have been able to shoot many great videos of my seven month old daughter. The camcorder came with Panasonic's video editing software, however, after trying a few times to meld clips and edit them, I grew frustrated with the lack of ease and intuitiveness that the software possessed.
I'm looking for video editing software that's easy to use and does a great job. I've read a bunch of reviews on some of the top software products out there, such as Adobe or Sony, however, many of them state that these are not geared toward novice editor such as myself.
Any suggestions would be amazing. I'm not looking to add audio or special effects; just simply take a bunch of shorter video clips and meld them into one condensed, edited clip.
Thanks so much for your suggestions!!
-Nick
seinfeld1104 is offline
post #2 of 6 Old 07-02-2012, 12:30 AM
brunerww's Avatar
Quoted: 58 Post(s)
Liked: 37
-Nick
Nick - have you tried the free editors that come with most computers? (iLife/Movie if you have a Mac or Windows Movie Maker if you have a Windows 7 machine).
One of these should work fine to edit your short clips into a longer, edited clip.
Cheers,
Bill
Hybrid Camera Revolution
brunerww is offline
post #3 of 6 Old 07-02-2012, 11:12 AM
bsprague's Avatar
Quoted: 494 Post(s)
Liked: 180
Nick,
The other Bill is correct, Windows Movie Maker may be what you want. He is used to me adding to his brief suggestions. Here is what I did.
My timeline is about the same. I bought a Panasonic SDT750 a few months before you bought your 800. I started with the Pansonic HD Writer and still use it to transfer and catalog all my video on my computer. And, I still use it to edit where I want everything to stay in 1080p60. Once I got used to Panasonic's version of "work flow" it went pretty smoothly.
Next I tried Windows Movie Maker that can be downloaded as a a free addition to Windows 7. I liked it. It is easy. It is also limited. Although, the rendered output quality is good, I didn't like how the 1080p60 was handled.
Next I tried Sony Vegas Home Movie Studio Platinum HD 11.0. It is the under $100 version of their very much more expensive pro version. I got it on a weird sale at Fry's with a $70 rebated. I liked it a lot and it was beginning to "grow on me". After about a month, a version update opportunity appeared and I tried it. The process eliminated all the help files. Sony instruction were to re-install the software from scratch. That messed with the copy protection tied into the registry file and it would not run. It took Sony support a month to email me that I needed to create a new user and it might be OK.
With a month available, I tried Adobe Premier Elements 10. It is Adobe's version aimed at consumers for around $75. Their pro version is over $600. The delightful part of PE10 is that it has levels of tools. At the top, it is very easy and straight forward. It is easy to learn how to quickly trim, arrange clips, include transitions and add titles. it even has some automatic movie generation features (that I don't like very well). Should you want to dig deeper it can give you control over everything from color to camera shake by applying "effects". When you are done with your video, there are a variety of choices to produce optimized versions for everything from YouTube to Blu-Ray players. No, it is not perfect. Although it handles every file format my camera can make, it will not render to 1080p60. Instead, it offers other choices that do play beautifully on my 55" TV. Some reviews will be negative, but those seem to come from people with older computers with limited capacity. Overall, it is widely accepted around the world with many support and training tools. My favorite training tool is at http://www.lynda.com.
Let me know if there is something I can do to help you get HD Writer to work better. My version is 2.6 and I think the 800 came with 3.0, but we will see.
Bill
bsprague is online now
post #4 of 6 Old 07-02-2012, 03:18 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
Windows Movie Maker will reduce your 1080/60p video quality, I wouldn't use it. What is it that Panasonic's supplied HD Writer software won't accomplish for you? You can combine clips, add transitions, titles and music, all while outputting a 1080/60P native file.
Go Phillies! Go Eagles! Go Sixers! Go Flyers!
tingham is offline
post #5 of 6 Old 06-16-2013, 09:40 PM
Kwilk6's Avatar
All,
I have been using the HD Writer software that came with the Panasonic HDC-SDT750PP and need a means of converting all the video I have into AVI or a similar file format for our home theater system (i.e. MP4, DIVX). In the past I have burned a DVD and ripped it in order to accomplish this task and not only is it a very time consuming process, it required I use a lot of DVD's. Does anyone know of a better way to convert the files?
Respectfully,
Kent
Kwilk6 is offline
post #6 of 6 Old 06-17-2013, 12:30 AM
bsprague's Avatar
Quoted: 494 Post(s)
Liked: 180
Originally Posted by Kwilk6 View Post
All,
Respectfully,
Kent
Don't convert. Buy a WD TV Live. It will play everything you have, as is, through an HDMI into your Home Theater. The $100 model will use a spare external HDD or your video backup HDD. The $200 model has it's own HDD. Mine will even play my 3D from the SDT750 if I manually switch the TV.
Reply Camcorders
