Importing video using a Mini-DV camcorder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-04-2012, 04:15 PM - Thread Starter
guidoia's Avatar
I was wondering if importing a VCR tape or VHS-C was better when using a Mini-DV camcorder than opposed to a Video capture card or a video - usb cable. I have a couple USB tv tuners that have input cables on them but have been very unhappy with the quality. I have many home movies I wish to convert to digital. Thanks,
guidoia is offline
post #2 of 10 Old 07-04-2012, 10:37 PM
sabatical's Avatar
Yes you should definitely use your miniDV camcorder as an analog --> digital converter. Any video capture card that uses a USB cable is sub standard and will produce poor quality transfers.
You should connect your VHS-C/VHS deck to your miniDV camcorder using an S-Video (preferably) or Composite cable and then use a Firewire cable from your miniDV camcorder to your PC.
You will need to ensure that your miniDV camcorder has analog pass-thru enabled.
To 'capture' the video on your PC, use Adobe Premiere, Sony Vegas or even Windows Movie Maker (but make sure you tell WMM that you're capturing DV-AVI). If you want a simple and straight forward capture program, check out WinDV: http://windv.mourek.cz/
Files captured by the above method will be approximately 13GB / hour in size.
sabatical is offline
post #3 of 10 Old 07-10-2012, 08:47 PM - Thread Starter
guidoia's Avatar
Thanks for the info. I was hoping you would say that. Looks like a good way to do it. I am using Sony Vegas and have been very happy with it so far. I see a few cheap camcorders out there and am leaning toward the Canon ZR60 for the importing of video. Price is cheap, does stereo and has S-video inputs. I will try to let everyone know how I turn out.
- Mark
guidoia is offline
post #4 of 10 Old 09-19-2012, 08:39 PM - Thread Starter
guidoia's Avatar
I have not been able to import video from my VCR using the camcorder I got off of Ebay. It is a Canon Elura 80 which seems to function normally in every way. I turn on the function to pass through the video which is coming into the camera. I see and hear the recording from the VCR playing on the screen of the camcorder. When I select the capture feature from the software the screen goes blue and the tape says it is playing. I get about a second of video capture and that's about it. I have tried this from Sony Vegas and from Microsoft Live Movie Maker and on two different computers. I must be doing something wrong so I could use some assistance if anyone has any ideas. Thanks, Mark
guidoia is offline
post #5 of 10 Old 09-20-2012, 01:34 AM
flintyplus's Avatar
Quoted: 161 Post(s)
Liked: 34
Not many dv cams will record video in,i have a Canon HV30 that will also a Sony D300 mini dv recorder player that will record video in.
flintyplus is offline
post #6 of 10 Old 09-20-2012, 06:34 PM - Thread Starter
guidoia's Avatar
According to the manual that came with the camcorder and what I have read online, it should work.
guidoia is offline
post #7 of 10 Old 09-21-2012, 04:19 AM
mvpers's Avatar
and you are connecting to your pc via firewire?
your PC is recognizing the camcorder?
i looked at the manual for your camcorder, it appears it should work exactly as my sony does for this conversion.
mvpers is offline
post #8 of 10 Old 09-23-2012, 10:15 AM - Thread Starter
guidoia's Avatar
Yes, I am connected through Firewire and it is recognized by the computer. When I tell it to capture the camcorder goes into play mode. Is that what its supposed to do?
guidoia is offline
post #9 of 10 Old 09-26-2012, 07:48 PM
sabatical's Avatar
Try putting in a miniDV tape in the camcorder while you're doing the transfer. I've heard that some camcorders require this.
Alternatively....
I know this isn't the most efficient way of transferring your videos, but you could record your VHS-C tapes onto miniDV tape first and then transfer them to your PC via Firewire.
post #10 of 10 Old 09-28-2012, 02:43 AM
flintyplus's Avatar
Quoted: 161 Post(s)
Liked: 34
If your model will record from an analogue source i would record the analogue footage to DV tape and then import the DV tape into the pc.
Reply Camcorders
