Broken hand strap on Panasonic HDC-TM700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-05-2012, 05:25 PM - Thread Starter
jader201's Avatar
I just broke the strap on my Panasonic HDC-TM700 (see below -- not my camcorder, but as a reference). I broke min right there in the front.
Any idea if I can DIY repair, or will I have to contact Panasonic? Or can they even fix it? There doesn't seem to be an easy way to do this, as the strap was sown and can't be detached/reattached.
jader201 is offline
post #2 of 3 Old 12-10-2012, 01:38 PM
callmeacab's Avatar
I just had a similar problem on my HDC-TM700. On mine, it appears that the front connector (the piece that fits into the connector slot) is completely missing. Just wondering if you had any success in fixing your borken hand strap problem? Was it an after-market solution or through Panasonic? Thanks.
callmeacab is offline
post #3 of 3 Old 02-06-2016, 01:46 AM
Liked: 0
Any solution?
Hi jader201
I have the same issue. My hand strap from my HDC-SD707 (same like TM700) is broken at the front.
Biggest issue for me is, I cannot find a replacement hand strap? And Panasonic is not offering a great contact option or replacement parts shop?
Have you found a replacement part - and shop to get it?
Replacing it I can do myself I think. I found an instruction video on how to replace the strap (cannot post link here but search for "hand strap panasonic tm15 replacement fixit")
Dennis D.
Doffie is offline
Reply Camcorders
