Recording projector screens & presenter in a dim room - trying to improve - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-07-2012, 12:39 PM - Thread Starter
zirconx's Avatar
I have started recording presentations. I bought a camcorder and a wired mic. I choose a Canon HF10 for its large sensor, external mic input, manual audio controls, and I could afford a used one ($150). But I am not happy how the videos are turning out. Recording a bright projector screen and a dimly lit presenter is difficult. You can see an example here (at the 5 min mark he walks in front of the screen):
http://www.youtube.com/watch?v=wrU69Eqe8Oc&feature=plcp#t=5m
The presenter looks good when he is in front of the projector screen, but when he's not he looks pretty bad. What can I do to improve? Do I need a different camera?
One thing that bothers me is that the video always looks better in Sony Vegas. When I "render" the video in Vegas, the result is always darker and contrasty. Even when I open the source file in Windows Media Player it seems darker and more contrasty than when I view the file in Vegas. I think I've tried almost all the codecs in Vegas. Is there a different one I should be using?
I am thinking about buying a Panasonic GH-3 next year when the price comes down a little. Would this camera do better? Any other advice? Thanks.
zirconx is offline
post #2 of 3 Old 10-07-2012, 05:44 PM
Chas Tennis's Avatar
No experience with your problem.
Projection screens usually have a retro-reflective coating similar to street signs such as "STOP" signs. These screens usually have little glass beads that send light approximately back in the direction that it came from with controlled spread. You can examine how they reflect light by punching a hole in a piece of opaque cardboard and shining a laser pointer through the hole. If the screen is brighter over, say, a cone of 20° then see if you can position the cameras outside this brighter reflection cone, probably a forward row and off to the side. You should also be able to determine this brightness by walking around when the projector is working. (Similar directionality for computer monitors and TVs.)
Rear Projection Screens. These also have directional characteristics similar to the retro reflective screens. These screens may spread a beam into a cone that is also intended to reach the seats of the conference room and not send light to the walls or ceiling, etc. .
A second more cumbersome method would be to place a neutral density filter some distance from the camera, 12"?, so that it appears over only the screen but not the speaker. It would work best if cut to the approximate width/height ratio of the screen. [Kodak Wratten plastic ND filters had good optical quality and could be cut to size.]
Chas Tennis is offline
post #3 of 3 Old 10-10-2012, 06:33 PM - Thread Starter
zirconx's Avatar
Thanks for the suggestions.
zirconx is offline
Reply Camcorders
