turning off button sounds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-30-2012, 11:56 PM - Thread Starter
tabc's Avatar
Hi
I've purchased a HDR-AS15 to replace a GoPro but wish to silence all the sounds that the camcorder does when turning on/off etc. Does anyone know how to do this....? Sony say that it can't be done but I'm hoping someone out there has been able to over ride these sounds.
Cheers
tabc is offline
post #2 of 3 Old 10-31-2012, 10:16 AM
markr041's Avatar
Quoted: 922 Post(s)
Liked: 293
There is no way to mechanically turn of the settings sounds when you press the buttons. BUT, if you control the camera by WiFi it may not make the sounds, as no on-camera buttons are pressed. You have the wifi version, and both an Apple and an Android app is available to control all the settings (and view in real time). Try this - I have not checked whether sounds are made via remote control.
markr041 is online now
post #3 of 3 Old 02-21-2013, 01:22 PM
dismatic's Avatar
Have their been any developments with this? Does using the WiFi control stop the noises?
dismatic is offline
Reply Camcorders
