Canon M500 performance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-27-2012, 05:06 PM - Thread Starter
ProfessorCPA's Avatar
I bought a black Friday special on Amazon and I'm pleased with the quality for under $350. The only thing that concerns me is the lack of wide angle. Is there a wide angle lens that fits on this camcorder? I know there is one out there (Canon) that sells for around $200 but not sure if it is compatible. I know it'll make the camcorder very front heavy but I like shooting family get togethers inside.
Thanks for any advice.
ProfessorCPA is offline
post #2 of 2 Old 11-29-2012, 09:39 PM
Blasst's Avatar
Quoted: 67 Post(s)
Liked: 65
There are cheaper models from other companies, though I would stick with the Canon model. I have it on my M41 and it works great. Can be found online for $200 bucks.
http://www.amazon.com/Canon-WD-H43-Angle-Converter-Camcorders/dp/B000NJD13G
http://www.usa.canon.com/cusa/consumer/products/camcorders/consumer_camcorders/vixia_hf_m500#SuppliesAndAccessories
Blasst is online now
Reply Camcorders
