What type of video camera should I get for music videos? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-17-2012, 07:38 PM - Thread Starter
Reasynn's Avatar
So basically I want to save up for a nice video camera. As of now I have a Go Pro HD2 and I really want a better option. It's gonna be used for making music videos. I'd be open to spend around $1200 tops. Maybe stretch it to $1500. What do you guys recommend?
Reasynn is offline
post #2 of 5 Old 01-01-2013, 09:27 PM
adam1024's Avatar
For a video camera, have you considered T4i?
adam1024 is offline
post #3 of 5 Old 01-01-2013, 09:27 PM
adam1024's Avatar
Image sensor size 22.3 x 14.9 mm approx.
Approximately 18 million pixels Effective Pixels
Can simultaneously record RAW (14-bit) + JPEG Large
RAW: Approximately 17.90 megapixels (5184 x 3456)
adam1024 is offline
post #4 of 5 Old 01-01-2013, 09:28 PM
adam1024's Avatar
Check the features
adam1024 is offline
post #5 of 5 Old 01-02-2013, 01:11 AM
brunerww's Avatar
Quoted: 58 Post(s)
Liked: 37
Hi Reasynn - welcome to the forum. A couple of thoughts for your consideration. If you want a camera with the large sensor, shallow depth of field "look" seen in most music videos, there are a few choices - some with camcorder ergonomics - some with still camera ergonomics.
Among the camcorders at your budget level, my recommendation would be the $1100 (body only) Sony NEX-VG20. I have shot with this camera, and it produces great 1080/60p and 1080/24p images with very few caveats (e.g., it is susceptible to moire, has a consumer 3.5mm mic input and is incompatible with the new Sony power zooms).
With two $149 Sigma 19mm and 30mm lenses for a total of $300, you will have a great video camera with 2 very good prime lenses for $1400. Here is what this camera can do:
Among the still cameras at your budget level, I recommend the soon-to-be-available $1300 Panasonic GH3 and a $149 used Sigma 30mm lens to get started. This camera also shoots great 1080/60p, 30p and 24p images - has a headphone jack for monitoring audio (like a camcorder), has a viewfinder and autofocus that continues to work in video mode - and has no video clip length recording limits (unlike Canon and Nikon DSLR cameras). Here is what this camera can do:
If you want to save some money, don't need 1080/60p and have an external audio solution for headphone monitoring, I recommend a pre-owned copy of the GH3's predecessor model, the $499 Panasonic GH2 and, again, the great value-for-money Sigma 19mm and 30mm lenses. Here is what this camera can do:
Canon and Nikon DSLRs are unsuitable for video, in my view, due to their 12-22 minute video clip length limits, the complete failure of their viewfinders in video mode and their poor or nonexistent implementation of video autofocus (e.g., noisy lenses, autofocus hunting - see my test of the Canon T4i's video autofocus here).
Hope this is helpful, good luck with your decision, and Happy New Year!
Bill
Hybrid Camera Revolution
brunerww is offline
Reply Camcorders
