Camcorder Help needed for Church!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 12-31-2012, 03:10 PM - Thread Starter
jjessup0002's Avatar
Hello All. I’m currently working in the Media Ministry for my church. The church currently records services and events and plays them weekly through my local cable company. I’m fairly new to the Media Ministry and have run into a huge problem. The video capabilities are inadequate. We currently have a no name used camera that’s probably 10 years old. I've been tasked with upgrading the system.
I've been on Google all day long and am slightly more familiar with camcorders then I was yesterday. While not well versed in with cameras I am great with technology. I am currently Team Lead for a I.T. company and have several people around me who are familiar with cameras (but not familiar enough for what I need) so feel free to use any terminology needed to help. I will first describe our current setup and then describe what we would like to do.
Current setup:
• We have a very old camera that records crappy videos and records voices even worse.
• Camera currently sits on Tripod in back of sanctuary.
• We have DVD burner with audio video that records real time from the camcorder.
• At the end of the service we edit the title of the track and finalize the DVD on the DVD burner.
• We then take the master copy and make copies on a DVD copier.
• We take a DVD to the local cable company that then airs the service twice a week.
• An additional problem is that the sound system is pretty horrible as well which we are currently upgrading and the lighting of the pulpit isn’t that great. They have been adjusting the lighting in an attempt to improve quality but have decided that it would be best to find the right camera before proceeding with the lighting.
Desired Setup:
• We would like to maintain the ability to record real time from camcorder to DVD burner.
• Would like for service to fit on only 1 DVD (some people suggest blue ray needed since it can run 1.5 hours.)
• Camera still needs to be able to sit on sanctuary.
• Would like capability to either record with external mic or directly from audio systems.
• Would like to record in true HD. (have been told I need at least 30 fps for TV quality and 60 fps for HD quality)
As far as the budget goes, I would like to keep it under $1,000 but could go higher if the result would be worth it. By selling this horrible quality film we made $460 in 2012 so I’m sure a good product would easily double or triple the profits allowing the camera to pay for itself time and time aain.
jjessup0002 is offline
post #2 of 15 Old 12-31-2012, 10:41 PM
Chevypower's Avatar
Liked: 40
Try to get this
1/3'' sensor with XLR audio inputs (you can take in from the audio mixer).
http://pro.sony.com/bbsc/ssr/product-PMW100/ 1/3'' sensor
If the church is broadcasting and is interested in a multi-camera, you can do that with this camera (you just need more than one) so you can buy one and get more later.
This cam has timecode input, genlock (to sync multiple cameras), and SDI output (for live HD feed)
Live Blu-ray/DVD recording http://www.amazon.com/JVC-SR-HD2500US-Blu-Ray-Recorder-Capacity/dp/B007ZW744Q/ref=sr_1_4?s=electronics&ie=UTF8&qid=1357022907&sr=1-4&keywords=HD-SDI+switcher
Feed the camera straight into this Blu-ray recorder, or take the multi-camera feed from this mixer below.
Mixer w/ SDI and genlock
http://www.amazon.com/Panasonic-MULTI-FORMAT-DIGITAL-MIXER-AG-HMX100/dp/B004FK2CUC/ref=sr_1_1?s=electronics&ie=UTF8&qid=1357024239&sr=1-1&keywords=AG-HMX100
Chevypower is offline
post #3 of 15 Old 01-01-2013, 03:06 AM
brunerww's Avatar
Quoted: 58 Post(s)
Liked: 37
chevypower - That would be a great setup, but I think you missed the part about their $1000 budget.
jjessup - that's a tough problem to solve for $1000.
First - to clear up a few misconceptions. You have been misinformed about the relationship between frame rates and "quality". Number of pixels resolved or lines of video resolution are much more important numbers than frame rate.
So a camera that resolves 1920x1080 pixels at 24fps or 30fps will give you higher image quality than a camera that resolves 1280x720 pixels at 60fps, for example.
Also, you are limiting yourself by delivering your product to the cable company on DVD. I suggest a conversation with your cablecaster to see whether they can take an SDHC/SDXC card straight out of a modern HD camera. If so, you can pull the SD card out of the camera at the end of the service, add your title on a PC in an editing program, copy the file back to the card, take it to the cable studio for transmission - and maintain full HD quality.
That said, given that you have the camcorder on a tripod in the back of a poorly lit sanctuary, I recommend the Canon HF G10. Even though it is a couple of years old, it is still the low light champ among camcorders at the $1000 price point. New, they are a little over $1000 at $1079 brand new at Amazon.
Here is what the HF G10 can do in a poorly lit church setting (please watch at 720p):
Here is a wedding shot with this camera:
Your sound challenge is a separate issue, and a new camera will probably not solve that - but at least you will raise the quality of your video - and you can use that as an argument to spend the resources required to raise the quality of your sound and lighting.
Blessed New Year to you,
Bill
Hybrid Camera Revolution
brunerww is offline
post #4 of 15 Old 01-01-2013, 05:36 AM
biomedtech's Avatar
Bill,
Thank you for your examples of video. They show just what needs to be said, that a quality camera at the back of a large room isn't going to capture as much detail. Your videos are properly framed for the ceremony taking place. This quality is just not possible with a satellite camera.
Sound is not as expensive to enhance, just requires a feed to a small powered speaker close to the camcorder so that audio is received 'near field'. How the congregation is best mic'd, is something to be learned by trying.
For example:
Cheap: A lapel mic for minister, wired, very inexpensive, but a pain to be 'tethered'.
Better: Add one 'vocal' mic for the choir, the least expensive quality mic is a Shure SM-58, $85. Very robust and it takes alot of abuse.
Even Better: If you have any budget left over, a shotgun mic (with dedicated person) to follow other interaction in the congregation. Heck, you could even strap a Go HD Pro with its mounting accessories, to the boom pole so that an 'alternate' video would always follow the shotgun, stored on a convenient memory card.
biomedtech is offline
post #5 of 15 Old 01-01-2013, 10:21 AM
Chevypower's Avatar
Liked: 40
I guess I was focussing on the part I bolded below.
post #6 of 15 Old 01-02-2013, 08:32 AM - Thread Starter
Thank you guys for all of the feedback. All of my co-workers agree that any of these will be good solutions. I will present this information to the finance committee and hopefully purchase one of these cameras. Again, thank you all!!!!!
post #7 of 15 Old 04-08-2013, 06:14 AM - Thread Starter
So I bought the Canon HF G10 as you guys suggested. I love this camera. It addresses all of the issues that we were having.
I do have a new problem though. The camera records in the .MTS format (MPEG-TS). The software that came with the camera is crap. It only accepts DVD-R when converting to dvd format. Can anyone recommend some free software that will allow me to convert MPEG-TS files to a DVD format that can be burned to DVD+R discs?
I have started a new thread an you can reply to either.
You guys have been awesome so far and i'm hoping you are able to help again.
http://www.avsforum.com/t/1467260/converting-mpeg-ts-to-dvd-player-format
post #8 of 15 Old 12-28-2015, 07:33 AM - Thread Starter
Memory Issues
So, this awesome camera that i've purchased is starting to crap out on me. It keeps shutting down and giving an error stating internal memory read error, and then asks me if i want to recover the data.
Recovering the data doesn't do anything. I've reset the camera multiple time, assured the internal memory isn't full as well as the SD cards. I've even tried running it without the battery in it but it's still shutting down.
I'm stumped and really don't want to have to ship this camera back to Canon. Any suggestions?
post #9 of 15 Old 12-28-2015, 09:41 AM
jogiba's Avatar
Quoted: 653 Post(s)
Liked: 347
It might not be worth fixing a three year old camcorder if the cost is high.
http://www.ebay.com/itm/Canon-Vixia-...4AAOSw1S9WfC3W
jogiba is offline
post #10 of 15 Old 12-28-2015, 11:02 AM
Quoted: 88 Post(s)
Liked: 32
Did you initialize the internal memory? If not, choose the option for full initialization.
xfws is offline
post #11 of 15 Old 12-28-2015, 11:23 AM - Thread Starter
I've done that, no luck. I basically use the camera for 1.5 hours at a time once per week. After formatting the SD card and resetting the camera it will work for 1 week and then stop in the middle of recording the following week.
post #12 of 15 Old 12-29-2015, 04:56 AM
Quoted: 1701 Post(s)
Liked: 731
Is it possible that the memory card is corrupted?
Do you have another card you can try?
JimP is offline
post #13 of 15 Old 12-29-2015, 05:04 AM
kucharsk's Avatar
Quoted: 1436 Post(s)
Liked: 781
Sounds like the solution for the time being is simply to reset the camera and reformat the SD card each week before or after service.
kucharsk is offline
post #14 of 15 Old 12-29-2015, 05:29 AM
jogiba's Avatar
Quoted: 653 Post(s)
Liked: 347
Quality memory cards are dirt cheap, get a few.
http://www.bhphotovideo.com/c/produc...rd_80mb_s.html
jogiba is offline
post #15 of 15 Old 12-29-2015, 07:13 AM - Thread Starter
I've actually tried a new memory card already. I just bought a 32 gig from Samsung but no luck.
I may just have to send it in to canon and let them investigate. I hate that they don't have any diagnostic tools available for you to use.
Reply Camcorders
