Combining m2ts files - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-11-2013, 04:00 PM - Thread Starter
JediSpork's Avatar
I was wondering is there any simple software besides tsmuxer for combining m2ts files? I am looking for ubuntu and windows options. I don't usually like using software that is no longer supported. I have a panasonic cam and only copied over the m2ts file but hd writer I think wanted the whole directory. I may just leave the files alone as their doesn't seem to be a lot of options.
My plan was to combine the m2ts files so I don't have 20 clips from a birthday party etc and then run them through handbrake. Or do you think it is worth re-encoding the files?
JediSpork is offline
post #2 of 7 Old 01-11-2013, 04:12 PM
Paulo Teixeira's Avatar
Quoted: 89 Post(s)
Liked: 50
Paulo Teixeira is online now
post #3 of 7 Old 01-11-2013, 04:50 PM
Quoted: 88 Post(s)
Liked: 32
The "device explorer" in Sony Vegas Platinum versions 10, 11 or 12 will join mts files plus a lot more:
http://www.amazon.com/s/ref=nb_sb_noss_2/181-2138118-7028618?url=search-alias%3Daps&field-keywords=sony+vegas+platinum&rh=i%3Aaps%2Ck%3Asony+vegas+platinum
xfws is offline
post #4 of 7 Old 01-11-2013, 05:16 PM
markr041's Avatar
Quoted: 936 Post(s)
Liked: 296
Will it do that without re-encoding all the clips? I don't think so. And if not you lose resolotion and you wait. ts muxer, and the recommended tmpengc program combine mts clips without re-ecncoding whole clips, and instantly.
markr041 is offline
post #5 of 7 Old 01-11-2013, 05:27 PM
Quoted: 88 Post(s)
Liked: 32
I don't see any issues with quality joining and rendering files from Sony Vegas.
There's the added benefit of being able to tweak the audio, color, sharpen, add fx, etc.
If you like to keep your footage in it's purist form and then upload, that's fine. For me, I like the ability to edit and refine the image.
xfws is offline
post #6 of 7 Old 01-11-2013, 05:30 PM
markr041's Avatar
Quoted: 936 Post(s)
Liked: 296
I'm not arguing either way, just pointing out this distinction - almost any software now will joint mts files (there is nothing special about Vegas for this). But few do it losslessly, and also have some other features + work with all brands of .mts files.
markr041 is offline
post #7 of 7 Old 01-11-2013, 06:20 PM
Ungermann's Avatar
Quoted: 667 Post(s)
Liked: 101
Why would you do that? Do you edit in camera (a.k.a. "Straight8" style) so that you clips do not require any editing at all?
Ungermann is offline
Reply Camcorders
