Compatible memory cards question for Sony GW55 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-16-2013, 06:43 AM - Thread Starter
tonantos's Avatar
Hi All
I recently purchased the Sony GW55 handy cam, which is absolutely amazing. The next step is to purchase a compatible memory card. I know it takes any Class 10 Micro SDHC cards but I'm curious about the importance of the write speed of said cards.
Most micro SDHC cards only have a write speed of about 12mbs (read speeds are considerably higher). However, when I set my GW55 to record at it's highest definition it records at 28mbs, which is a lot higher than any existing micro SDHC cards can handle. How does this work? Does that mean I am unable to record at it's highest quality because I'm limited to the memory card's max write speed? As such, I don't understand how it can just take any class 10 micro SDHC?
I know these are stupid questions but I'm completely illiterate when it comes to camcorders so any help would be much appreciated.
Thanks in Advance
tonantos is offline
post #2 of 4 Old 01-16-2013, 07:48 AM
David Sholle's Avatar
The highest AVCHD recording data rate for the GW55 is 28 Mbps - notice the small b, Mega bits per second. What you have written as 12 mbps recording rate you give for class 10 microSD cards is not correct. It should be 12 MBps or 12 MB/s, which refers to Mega Bytes per second, and since there are 8 bits per Byte, that means the card can record at 96 Mbps, easily handling a data stream of 28 Mbps.
I have the GW77, and I'm not sure what the difference is between the GW77 (sold in the US and maybe elsewhere), and the GW55, which is not sold in the US as far as I know. I discovered that microSDXC cards work in it, which is nice, as microSDHC cards top out at 32 GB, while microSDXC card go all the way to 2 TB (but none yet exist at that capacity). Over the holidays BHPhoto had Sandisk 64 GB microSDXC cards for $50. Currently they are $60.
Good luck with your GW55. If it is like the GW77, it should be a great travel camcorder.
Also, when you transfer files from the camcorder to your computer, the camcorder only has a USB 2.0 connection, even if your computer has USB 3.0, so the transfers are OK, but not really fast. If you have an SD card reader built into your computer, it probably is worthwhile to remove the microSD card from the camcorder and use the SD card reader to input data to the computer. For example, in one test I did transferring 2.85 GB of data, it took 4 min 11 s via USB (even though my computer has USB 3) and 1 min via the SD card reader built into my laptop.
David Sholle is offline
post #3 of 4 Old 01-16-2013, 08:03 AM - Thread Starter
tonantos's Avatar
Ah that would explain it. I completely missed the lower case "b" and the upper case "B". Thanks very much David.
From what I have researched up, the only difference between the GW77 and the GW55 is that the GW77 comes with internal memory. Unfortunately it's not available in Europe. The GW55 comes with no internal memory, hence why I was researching up compatible memory cards.
Well now that I have my answer, I guess I can just purchase any class 10 SDHC / SDXC card, ready for my snowboarding trip =)
Thanks again!
tonantos is offline
post #4 of 4 Old 01-16-2013, 09:05 AM
Ungermann's Avatar
Quoted: 663 Post(s)
Liked: 99
You also confused "m" with "M".
Ungermann is offline
Reply Camcorders
