Underwater case for Panasonic TM700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-19-2013, 07:57 AM - Thread Starter
v1rtu0s1ty's Avatar
Hey guys,
I need your help. Do you know where I can buy an underwater case for my TM700? I don't need something expensive. I just want something that works and something that is not bad quality. I'll use it to capture whale sharks next two weeks.
Any help would be greatly appreciated.
Ronneil
v1rtu0s1ty is offline
post #2 of 5 Old 01-19-2013, 08:22 AM - Thread Starter
v1rtu0s1ty's Avatar
post #3 of 5 Old 01-20-2013, 07:49 PM
kkfok1031's Avatar
I am using one by Reasea.
How deep do you want to use it? If it is for scuba diving I think Reasea, Sealux and Equinox are the way to go.
kkfok1031 is offline
post #4 of 5 Old 01-21-2013, 06:12 AM
PipeSurfer's Avatar
The one you posted says it can go as deep as 32 feet. The equinox one is about $900 which says it can go 250 feet deep.
PipeSurfer is offline
post #5 of 5 Old 01-22-2013, 01:02 PM - Thread Starter
v1rtu0s1ty's Avatar
Maybe only 10-12 ft. I'm good with the one I bought. It's arriving this coming Friday. I hope the glass/plastic won't affect the quality too much.
Reply Camcorders
