TM700 and HD Writer question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-21-2013, 02:50 PM - Thread Starter
Hookani's Avatar
Hi all,
Tried searching for some info on this but couldn't find much. As most know that have a TM700 when you shoot long video and transfer to your computer it breaks the video into 4 GB parts. When using HD Writer to view the video you can view it as a single long video without glitches but when you try to join them together in an editor (I use Powerdirector) there is always an audio glitch at the point where the video parts are joined. Is there anyway to join the parts together seamlessly without the momentary drop of audio between parts?
Ho'okani
Hookani is offline
Reply Camcorders
