The Official Panasonic HC-V720 Owners Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 279 Old 02-22-2014, 09:07 AM
johnnyknoxsvill's Avatar
Quoted: 63 Post(s)
Hey guys I just got the V720 and i'm having problems getting it to work with Ustream and my computer. I can't get Adobe Flash to recognize the camera. Anyone else run into this problem? I have the Wi-Fi set up correctly
johnnyknoxsvill is offline
post #212 of 279 Old 02-24-2014, 07:24 AM
JesperB's Avatar
You can only stream directely to ustream from the camera. If you wish to plug the camera to your computer to use a broadcasting program (Wirecast, Open Broadcaster software or Flash) you have to connect the camera to an encoder (Black Magic or AverMedia) and from the encoder to your computer.
All the best
Jesper
JesperB is offline
post #213 of 279 Old 02-27-2014, 09:57 PM
padsalwaysthere's Avatar
Hi.. I recently purchased a hc v 720.. I had purchased it to record my lectures that I provide to students in my training centre.
Is there a suitable external microphone (other than panasonic) that I can use for recording my lectures. Can you provide me the specs for the microphone.
padsalwaysthere is offline
post #214 of 279 Old 02-28-2014, 06:35 AM
bsprague's Avatar
Quoted: 491 Post(s)
Liked: 180
Welcome to the forum!
As many will say, the hard part of video is audio! Besides Panasonic, there are several brands of mics. Leading brands that come to mind are Rhode and AudioTechna.
Without know a little more about your situation, few here will be able to help much. What is the room like? How far away is the camera? How much background noise is there? What is wrong with the audio that the camera is recording with it's built in mic?
Good luck!
Yury C likes this.
bsprague is offline
post #215 of 279 Old 03-04-2014, 10:42 PM
Thanks a ton bsprague... The room is roughly 600 sq ft and the camera would be positioned about 10 - 12 ft away from the speaker. I haven't tried with the built-in mic as I assumed that the surrounding noise may deteriorate the quality of the audio..
It would be great if you can mention the specifications for a suitable mic can be provided, as I am not sure whether the brands available in US and Europe would be available in India..
post #216 of 279 Old 03-04-2014, 10:43 PM
Good luck!
post #217 of 279 Old 03-05-2014, 05:53 AM
bsprague's Avatar
Quoted: 491 Post(s)
Liked: 180
Try something like one of these:
http://www.amazon.com/dp/B002GYPS3M/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=5UYKHOCXT09L&coliid=I1AVQ4NFQ998UP
http://www.amazon.com/Audio-Technica-ATR-3350-Omnidirectional-Condenser-Microphone/dp/B002HJ9PTO/ref=pd_cp_MI_2
Be sure you check the diameter of the plug in on the camera. You may need an adapter if the mic plug is the wrong size.
Yury C likes this.
bsprague is offline
post #218 of 279 Old 03-07-2014, 09:40 PM
thanks a lot.. will check n update..
post #219 of 279 Old 03-11-2014, 01:28 PM
Nikishek's Avatar
Is there any other way how to watch video from PC on camcoder than ustream? I dont want watch from tablet or smartphone. Only from PC. If I discovered that ustream has only 30 day trial period so I was pretty pissed off.
Tried VLC player as DLNA client but no luck.
I will be grateful for any advice
Nikishek is offline
post #220 of 279 Old 03-15-2014, 07:02 AM
paragondk's Avatar
I have been shooting a lot of nature with my v720, and noticed that the clouds and skies are darker and more purple than with my old TM80.
I tried flipping Backlight Compensation to On and it made the skies so much brighter and more natural! Can someone explain this feature to me, and why it is off by default?
When to use, and when not to use?
For outdoor scenes, what are your recommended settings? I shoot in 1050p, iZoom50 (sometimes go digital for faraway animals), face recog ON and face framing: all. Hybrid O.I.S is on, and no guidelines, gage or AGS.
It was the backlight compensation that really made my outdoor shots look more light and natural though. Kinda sad I just found it after returning from a long outdoors holiday. :-)
Unrelated: clipping pictures out of the videos with Panasonics HD Writer program produces vastly poorer scene-grabs than earlier. Where I would have the screenshots at about 2MB with my TM80, they are ½MB now. Is this a software issue - should I go back to an earlier version of HD Writer?
Yury C likes this.
paragondk is offline
post #221 of 279 Old 03-25-2014, 08:55 PM
daman_daman's Avatar
can the panasonic record clips while also reviewing on an ipad.
I am a football coach looking for a camera that can record while reviewing plays on the sideline via ipad.
we pause in between each play and would like to continue to record the game while also looking at previous clips on ipad.
has anyone tried this.
i have searched the forums but not a lot of people using the camera for what i want.
daman_daman is offline
post #222 of 279 Old 03-28-2014, 01:52 PM
xanbo's Avatar
Backlight compensation is to be used when your subject is in front of something very bright, like a sunny window. Putting the camera in Backlight Compensation mode tells the camera to adjust the iris and shutter speed for darker portions of the image to make them more visible.
xanbo is offline
post #223 of 279 Old 04-17-2014, 11:20 AM
lastquark's Avatar
Quoted: 13 Post(s)
What software do you all use to stitch several AVCHD files together seamlessly without re-encoding?
lastquark is offline
post #224 of 279 Old 04-17-2014, 11:29 AM
markr041's Avatar
Quoted: 764 Post(s)
Liked: 240
TMPGEnc MPEG Smart Renderer 4 is the only software that does what you want correctly. I used it for all my AVCHD videos.
http://tmpgenc.pegasys-inc.com/en/product/tmsr4.html
lastquark likes this.
markr041 is offline
post #225 of 279 Old 05-08-2014, 02:39 PM
ogarafgan's Avatar
Hello Prague,
I'm sorry i write here, but i saw you know lots about this Panasonic. I just bought the cam, i need it only for live streaming, i have a Avermedia capture card, i don't wanna use wi-fi, only through the pc. But on the image, the live image, where i broadcast, it can be seen too the logo, IA,IA+, MNL, etc. Would you please be so kind to tell me, how can i remove the logo?
THank you
ogarafgan is offline
post #226 of 279 Old 05-08-2014, 07:09 PM
bsprague's Avatar
Quoted: 491 Post(s)
Liked: 180
Originally Posted by ogarafgan View Post
Hello Prague,
THank you
I don't have a 720. I have a similar Panasonic that came with a remote control. It has a display button that changes the screen for direct playback on a TV. One choice is clear of all logos and symbols. The camera itself does not have that choice.
Hope that helps.
Good luck...
bsprague is offline
post #227 of 279 Old 05-09-2014, 06:53 AM
ogarafgan's Avatar
Thank you Prague for answer!
So i need a remote?!!! Lol, it doesn't have, what can i do? :(
post #228 of 279 Old 05-09-2014, 02:56 PM
bsprague's Avatar
Quoted: 491 Post(s)
Liked: 180
I'm familiar with an earlier model of the 720 and am guessing a little. On mine you could turn almost everything off from the camera menu. For the last piece you had to use the remote that was included. Your 720 is bound to be a little different.
Try looking on page 101 of this manual: http://service.us.panasonic.com/OPERMANPDF/HCV720_ADV.PDF
It says Menu > [SETUP] > [EXT. DISPLAY] > OFF
Does that do what you want?
bsprague is offline
post #229 of 279 Old 05-09-2014, 04:26 PM
ogarafgan's Avatar
Thank you Prague,
I talked today with my Romanian Panasonic representative and he thought me the same, with a try on TV. I mean i can see on my LCD the icon, but on the external display should not be seen in the MNL mod. Hope i solved it with your help. THank you very much and have a lovely day, night, whatever is on the road :)
post #230 of 279 Old 05-10-2014, 01:00 AM
JesperB's Avatar
Hi ogarafgan
I use the v720 for live streaming as well (with AverMedia Live Gamer Portable). It works great. You can remove all the information on the screen so you only see the picture on the computer. What streaming software do you use (I'm just curious).
One of my recorded live streamings can be seen here (with the v720)
http://www.ustream.tv/recorded/45640840
All the best
Jesper
JesperB is offline
post #231 of 279 Old 06-24-2014, 07:25 AM
jlenting's Avatar
Liked: 0
Hi everyone
I am considering purchasing the V720.
I will use the camera for the following:
a) Filming family type material (e.g. my 2 young kids, birthday parties, vacations, dogs etc)
b) Short film making
Now, I'm very interested in making the films look as good (and as professional looking) as possible.
Particularly for point (b) above.
And to that end, I want to achive decent looking "professional" footage- i.e. with nice shallow depth of field and cinematic 24fps.
My budget is $900
Will the v720 be able to give me this?
j
jlenting is offline
post #232 of 279 Old 06-24-2014, 07:46 AM
bsprague's Avatar
Quoted: 491 Post(s)
Liked: 180
Originally Posted by jlenting View Post
........I want to achive decent looking "professional" footage- i.e. with nice shallow depth of field and cinematic 24fps.
I don't recall if the v720 can shoot 24fps.
To get the "professional" shallow depth of field requires bigger diameter lenses which, in turn, require bigger sensors. That is why "professional" cameras cost so much. It is also why a few DSLRs from Canon are popular with "independent" film makers.
A compromise for the lowest budgets may be available from some mirrorless cameras. The Canon EOS M, although discontinued, is still available for under $400. It was demonstrated as a capable video camera in its own thread here months ago. Basically, it uses the larger sensors and lenses from the Canon system to provide you with the shallow depth of field options.
Similar depth of field control can come from the M43 (micro four thirds) system used by Olympus and Panasonic. Well past your budget is the GH4 from Panasonic that is getting positive excitement from "professionals". Withing the large family of the GH4 cousins there are cameras within your budget.
bsprague is offline
post #233 of 279 Old 06-26-2014, 04:10 AM
jlenting's Avatar
Liked: 0
After some research, i see that the EOS-m is basically a smaller more compact version of the 650d, and the compact size is what many people like about it.
But for me, the size of the camera is not really a factor.
Also, i see there are a few places where the prices are similar - so the M is not significantly cheaper.
So is there any other reason besides compact size and cost, that one would recommend the eos-m over the 650d for videography purposes ?
jlenting is offline
post #234 of 279 Old 06-26-2014, 05:47 AM
Quoted: 88 Post(s)
Liked: 32
The video quality is pretty much going to be the same. Note the viewfinder on the T4i is not active during video.
Comparison:
http://snapsort.com/compare/Canon-EO...anon-Rebel-T4i
xfws is offline
post #235 of 279 Old 07-22-2014, 07:49 PM
Lateralnw's Avatar
I'm using the V720 but I as I mentioned in another thread (by accident V700) I had a problem where the files would be broken in to 4GB sections. This is about 35mins of recording. The other thing I noticed is the last 0.5 secs of the recorded audio is missing.
I contacted Panasonic Australia via email and to my surprise rang me, unfortunately I missed the call however he did leave a message but no contact name. He suggested that my camera should be formatting the SD card in exfat and that the files are not broken up.
I had also asked if there was an update/firmware for the camera but said Panasonic didn't see a need for one.
My camera version is Ver.1.0 On the same menu under setup there is an option which is titled Version Up. When selected the camera attempts to read (Displays "Reading Card")the SD card and I assume is looking for a firmware update, so it is possible to be updated.
Both those things are not what I am experiencing in fact the opposite.
Could the owner of a V720 tell me what format their V720 formats in (e.g. fat32 or exfat or other) and if they also experience the 4GB file section. It would be terrific if someone could tell me if they have had the 0.5 sec audio loss between the 4GB file breaks.
Lateralnw is offline
post #236 of 279 Old 07-22-2014, 09:51 PM
Lateralnw's Avatar
Try looking on page 101 of this manual: http://service.us.panasonic.com/OPER...HCV720_ADV.PDF
An image to compliment bsprague advice.
Name:	Panasonic setup on HC-V720 Ext display menu merged640.jpg
post #237 of 279 Old 07-23-2014, 03:36 AM
jlenting's Avatar
Liked: 0
Lateralnw, just a question for you.
Do the split up 4gb files only occur when you are recording one coninuous 35 minute clip (or longer) ?
Also, does the 0.5 seconds of missing audio occur only once you have a 35 minute+ long clip ?
jlenting is offline
post #238 of 279 Old 07-23-2014, 04:20 AM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
The split is created as a result of formatting to FAT32. I understand that HDWriter will combine split files and restore the audio. This you could do before editing.
My filming is shot based, so no long videoing, and I have yet to come up against this problem as the file sizes are small. One way may be would be to stop and restart the video at a natural break. This would create two files that will combine seamlessly.
Two points:-
Have you ever seen 35 minutes of continuous single shot video? IMO it would be very boring.
I formatted my SD card to ExFat but the camera would not recognise it so I had to go back to FAT32.
Terfyn is offline
post #239 of 279 Old 07-26-2014, 12:26 AM
Lateralnw's Avatar
Audio dropped 0.5 secs or 24 frames
Yes...
0.5 secs occurs due to the camera automatically having to start a new file. I have also noticed that the lost audio is always equal to the last 24 frames. The time may be different but the frame count appears to be the same.
post #240 of 279 Old 07-26-2014, 12:41 AM
Lateralnw's Avatar
Two points:-
I have version 5 of HD writer and I have not been able to get it to combine the files. In fact it exports the files in 4GB chunks!
RE your points,
Haven't you every watched a live (recorded) performance?. You can't afford to stop the camera as it will be just then that something important happens. If you never recorded it you can't edit it out later. Its fine to start/stop the camera for home videos but I'm not using it for that.
I also tried to use a Exfat formatted SD card but the camera reports it as an error.
More importantly to me is do others have this problem with this camera. e.g. loss of audio of approx 0.5 secs or as I have now discovered the last 24 frames at the end of the 4GB file.
Reply Camcorders
Panasonic Hc V720 3d Ready 1mos Hd Digital Camcorder
