Deleting single event on Sony HDR-CX730 - AVS Forum | Home Theater Discussions And Reviews
Old 02-10-2013, 03:39 AM - Thread Starter
hadouma's Avatar
Hi all,
Maybe you can help me out on a problem that should not exist.
On my Sony HDR-CX730 I have multiple events and I want to delete just one of them. According to the manual that should be possible:
- Choose Edit/Copy
- Choose Delete
- Choose All in event
- use the arrow keys to select the event you want to delete
- delete
Unfortunately the selection using the arrow keys does not work. The header on the delete screen is showing multiple events in the date range 8 to 10 Feb and I want to delete just 8 Feb, but cannot select it. Instead it s treating it as a single event.
Does any of you have an idea how to get around this ?
hadouma is offline
