Upgrading From Kodak ZI8 - Need Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-10-2013, 07:53 AM - Thread Starter
MichaelStetina's Avatar
We make instructional videos indoors using a ZI8 and AT3035 microphone. I'm generally happy with the results:
http://www.getvisiblevirtually.com/online-business-manager/
Questions:
If I spent $100-200 more on a camera would the results warrant it? What camera would it be? I've also looked at a Sony HDR-CX190 but it doesn't have a microphone jack.
I'm looking at the Sony Bloggie Sport because the .mp4 output format will work without conversion in Sony Movie Studio Platinum 12 (the ZI8 outputs .mov). Am I being foolish to change for that reason alone?
How do I make 2 microphones work when my wife and I are on camera together?
Any other advice you'd care to give.
Thanks very much in advance!
MichaelStetina is offline
post #2 of 3 Old 02-10-2013, 12:34 PM
Robin_G's Avatar
I can't answer that question, but I can ask you one. Can you connect the ZI8 to a wall socket for power? For instance, if you're shooting a 2 hour interview?
Robin_G is offline
post #3 of 3 Old 02-10-2013, 01:05 PM - Thread Starter
Yes, it comes with an AC adapter.
Reply Camcorders
