Mount Wireless receiver for audio in - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-18-2013, 09:13 PM - Thread Starter
ralphbowman's Avatar
My understanding is the audio input on the side of the camera takes a 2,5mm sub mini stereo jack. I want to mount my Azden wr22 pro receiver , so I can place a lav on the speaker and get solid audio reception, the receiver will not make metal contact with the hot shoe nor would it need power from the hot shoe. I want then to plug a 1/8 mini jack into the receiver and then plug the other end into the camera's audio slot. I assume I will have to buy an adapter 1/8 mini into 2.5 mm sub mini. Will the camera receive the audio signal eventhough I am not making electrical contact with the hotshoe?
Separate question.... I see in the menu, Histogram, but it is grayed out and will not open. Do I need an upgrade to get this to function?
Any help will be appreciated.
Thanks ,
Ralph Bowman
ralphbowman is offline
post #2 of 3 Old 02-19-2013, 06:52 AM
bsprague's Avatar
Quoted: 595 Post(s)
Liked: 217
Ralph,
Welcome to the forum!
It would help if you mention what camera are you using.
Bill
bsprague is offline
post #3 of 3 Old 02-20-2013, 08:46 AM
Ungermann's Avatar
Quoted: 663 Post(s)
Liked: 99
1) It is 3.5 mm, not 1/8". Funny how you mix SI and imperial, as well as comma and point for decimal separator.
2) If your receiver gets power from a separate source, you obviously don't need to power it from a hot shoe.
Ungermann is offline
Reply Camcorders
