Buying an XL-1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-01-2013, 11:16 AM - Thread Starter
Wake4real's Avatar
I'm buying an XL-1 from a local guy and was curious what I should look for when inspecting it? I only have a few hours before we are meeting.
Just curious if there are any specific problems they are known for?
Thanks =)
Wake4real is offline
post #2 of 3 Old 03-01-2013, 02:32 PM
Paulo Teixeira's Avatar
Quoted: 78 Post(s)
Liked: 44
It might be too late but first things first is to check everything with it being actually turned on and it would help to have a tape to try and record some sample footage. Then see if it plays back properly and see if you can easily rewind and fast forward and then playing the tape again. This is a very old camera now and so you never know how many times the camera has been used so making sure the heads are good is very important. The lens is another place to check. For example see if theirs any noticeable scratches. Some smaller scratches might not show up in the video but big ones might. Looking at the camera's viewfinder is one way but if possible, playing back the newly recorded footage on a TV would be even better especially if theirs a ton of scratches on the lens and you want to see if that effects the video quality.
Again this is definitely an old standard definition camera and you should think really hard about this. it was released in January 1998 I believe. What is your budget? Perhaps you'd be able to get a nice HD camera instead.
Paulo Teixeira is offline
post #3 of 3 Old 03-01-2013, 03:55 PM
Ungermann's Avatar
Quoted: 523 Post(s)
Liked: 69
Thanks =)
Unless you are buying it for $50 I would not bother. Hmm, I am not sure I would by the XL-1 even for $50. That's old tech. Can it do widescreen? Can it do progressive? (Maybe it can do 30PsF). Well, the only good thing about it is CCD.
Ungermann is offline
Reply Camcorders
