Help with Camcorder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-08-2013, 06:44 AM - Thread Starter
k11ngy's Avatar
Not sure if I am in right section? just joined forum
I wanted to know if it is possible to record on camcoder and whilst it is recording, whether its possible to show on a projector through PC?
Is that live streaming or ?
Steve
k11ngy is offline
post #2 of 9 Old 03-08-2013, 07:52 AM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Welcome to the forum.
"live streaming" usually refers to sending video over the internet.
If what you want to do is record and watch on a projector at the same time, you want a camcorder with an HDMI port a projector with the same. You will project an exact duplicate of what is on the cameras viewfinder screen. When you are looking at camera, you want to find one that has an option to turn off every icon displayed. Having a PC in the loop is superfluous.
In other words, it is common for things like camera settings or the "REC" to be displayed while recording. Some camcorders allow that to be turned off and some not.
Bill
k11ngy likes this.
bsprague is offline
post #3 of 9 Old 03-11-2013, 03:35 AM - Thread Starter
k11ngy's Avatar
Thank you for your help and that has helped me no end- Thank you
Steve
k11ngy is offline
post #4 of 9 Old 03-25-2013, 06:04 AM - Thread Starter
k11ngy's Avatar
Hi Bill
Excellent news, it worked and thank you for help. Just one more thing
I will be recording a Fashion catwalk show for college and the sound will be the Music from inside the hall to accompany the catwalk show
When I put the Camcorder into projector (HDMI) I get a horrible squeaky sound. Am I able to stop that without having to turn off audio on camcorder as I will need it on to record the music in hall?
Steve
Bill
k11ngy is offline
post #5 of 9 Old 03-25-2013, 06:12 AM - Thread Starter
k11ngy's Avatar
Hi Bill
Steve
k11ngy is offline
post #6 of 9 Old 03-25-2013, 09:00 AM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
I think you may be talking about what is usually called "feedback". The microphone is picking up the sound put out by the speakers and sends it to them again in a loop. You have to move the mic further from the speakers, turn down the volume of the speakers or find a way to turn down the "gain" on the camera mic.
Hope this helps.
bsprague is offline
post #7 of 9 Old 03-26-2013, 03:08 AM - Thread Starter
k11ngy's Avatar
Thank you again and understand problem now
On the Gain thing, If I turn down or OFF does that shut off the Microphone in camcorder completely?
Appreciate help so far
Thank you
Steve
k11ngy is offline
post #8 of 9 Old 03-26-2013, 11:11 AM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Thank you
Steve
It is often said that the hardest part of video is getting good audio.
I assume your TV is in an area where the show is taking place so the audience will be hearing the live music and narration. They don't need the TV sound. Turn the sound (volume) on the TV to off or "mute".
The camera will continue to record.
If you are in a situation where you can't control the TV, they you have to do it at the camera. I think you will have to experiment with a manual setting that is low enough to prevent feedback but high enough to still record.
If none of this works, you may have to use a separate sound recorder of the type popular with musicians. A company named "Zoom" makes a few.
If your are trying to create a production quality music video, it will never happen with the onboard mic in your camera, no matter what you do.
bsprague is offline
post #9 of 9 Old 03-26-2013, 02:07 PM - Thread Starter
k11ngy's Avatar
Thanks again
Will keep experimenting
Cheers
Steve
k11ngy is offline
Reply Camcorders
