HCX-900M inmage stabilization (rocking up and down) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-11-2013, 01:09 PM - Thread Starter
Mlotsp's Avatar
Hi all,
I love my HCX-900M but I'm a little disappointed in the image stabilization. Don't get me wrong, I am happy with the overall stabilization results except for one thing I started noticing: The image will rock slowly up and down (left/right) . You will notice this when not panning the camera. For instance, when recording beach scenes, the horizon will slowly rock up and left/right like a see-saw. Does anyone have any advice on how to prevent this? Should I turn IS off? Any help/advice will be greatly appreciated!
Mike
St. Louis
Mlotsp is offline
post #2 of 3 Old 08-12-2013, 11:54 AM
Sanosuke1981's Avatar
Hi Mike,
This is noticeable with image stabilisation turned on. It can be avoided by turning off IS, however if you do that you will obviously encounter normal stabilisation issues. I also find it a little annoying at times, but generally the image stabilisation tends to work fairly well. Sorry I don't have a good fix! I would just suggest trying to keep the camera as stable as possible, even when IS is turned on. Also, turning guidelines on helps me ensure that I keep the horizon or other objects fixed in the frame when I'm filming - it's helped me avoid this problem with some of my footage.
Take care.
Sanosuke1981 is offline
post #3 of 3 Old 08-12-2013, 11:57 AM
Quoted: 88 Post(s)
Liked: 32
Originally Posted by Mlotsp View Post
Hi all,
Happens with Canon camcorders, also.
I think it's just the nature of the stabilization function.
If you put it on a tripod, turn off IS.
xfws is offline
Reply Camcorders
