Live Broadcast & streaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-24-2013, 08:03 AM - Thread Starter
KernowKards's Avatar
Hi folks i hope someone can help me , im lost in the world of wifi and live feeds and after many many hours searching and reading via google im now lost total brain strain
We currently film motorsports and rugby events here in the Uk and have now been asked to add horse jumping and football to our work load , which dont get me wrong is a step in the right direction
My question is in 2 parts , A. I want to be able to send live footage straight from the camera to the tv screen in the clubhouse of the rugby and football stadiums/grounds as most of them have a large lcd tv that they use for sky or dvd's etc , what would i need equipment wise to do this and B. some of our motorsport events are out in the open in fields or woodlands , what equipment would we need to broadcast this live over the internet.
many thanks in advance for any help from a very brain strained camerman
KernowKards is offline
post #2 of 4 Old 05-24-2013, 10:01 AM
jogiba is offline
post #3 of 4 Old 05-24-2013, 05:18 PM
Quoted: 88 Post(s)
Liked: 32
What is your budget? Is this pro-only or is a consumer camera ok?
Panasonic makes the v720 camcorder that can shoot 50 frames per second, which is good for action/sports £423.99
http://www.amazon.co.uk/Panasonic-V720-Full-Camcorder-Sensitivity/dp/B00B170BMI/ref=sr_1_1?ie=UTF8&qid=1369440554&sr=8-1&keywords=panasonic+v720
With this camcorder you can use UStream and can be viewed live on the internet or on a Smart TV that has the USTREAM app. If you don't have a Smart TV, you can get connections to connect PC to TV or just play it on a large PC monitor.
There are a number of options for viewing/making hardware connections, the main point is this camcorder can stream.
xfws is offline
post #4 of 4 Old 05-27-2013, 01:45 AM
psychobike's Avatar
These guys have been great and more then likely have all the needed bell & whistles to do what you need to do. They are the real deal in broadcast streaming. http://www.audiovideoweb.com/index.php
psychobike is offline
Reply Camcorders
