HF G30 xa10 batteries and other Q's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-09-2013, 04:29 AM - Thread Starter
terryuk22's Avatar
Do these take the same batteries and is it worth selling the xa10 for the xa20 or HF G30or even a Panasonic 920
terryuk22 is offline
post #2 of 3 Old 06-09-2013, 12:44 PM
brunerww's Avatar
Quoted: 58 Post(s)
Liked: 37
Hi Terry - The BP-808s from your XA10 will fit the £1299 HF G30 (which comes with the larger capacity BP-820).
I'm assuming you're in the UK? The only reason to sell your XA10, in my view, would be for 1080/50p - but I wouldn't want to give up the XA10's XLR mic inputs to get it. If you're considering the Panasonic X920, you might want to look at the £1649 Panasonic AG-AC90. Available now - with pro mic inputs, 1080/50p, and very good low light performance.
Here is how the AC90, XA10, HF G30 and X920/X929 compare on slashcam: http://camcorder-test.slashcam.com/compare-838dce54020e5940db948233dbe408da.html. Sadly, they have not tested the XA20 yet.
Hope this is helpful,
Bill
Hybrid Camera Revolution
brunerww is offline
post #3 of 3 Old 07-09-2013, 03:04 PM - Thread Starter
terryuk22's Avatar
thanks for that but batterys from xa10 dont work in g30 no luck with copies as yet
Reply Camcorders
