Camcorder vs Surveillance Cam to Broadcast live - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-28-2013, 12:30 AM - Thread Starter
OtterBoxing's Avatar
Hi there,
I'm not 100% sure if this would be the right sub-forum to post this, but I was looking to see if I could get some advice or tips..
Here's what I'm trying to accomplish.
I need to try and broadcast a class/lecture live from one room to a tv located in another room.
I would like to have 2 cameras mounted at the back of the room.
Camera #1 Pointed at the teachers podium
Camera #2 Zoomed in towards the whiteboard
Ideally I need a permanent solution, which is quick to setup at the begining of each class. Maybe the cameras can be continuously streaming, and all that would be needed is turning on the tv.
Or by using a survaillance camera system, that simply needs to be powered on, and will be live, right away.
I'm not sure if that makes sense.. but I'm wondering if it would make more sense cost wise, and functionality wise to use 2 x Handycams mounted, or a 2 Channel Surveillance camera system.
If anyone as has any input, tips, or advise, that would be greatly appreciated.
OtterBoxing is offline
post #2 of 2 Old 07-06-2013, 01:20 PM
dster77's Avatar
I would just buy two older (can be film) camcorders and then wire av cables to the next room. I would even put two tvs that way both the white board and you are always on. You can just bring the camera in and plug it in or leave them there and just turn them on and the tv on in the other room.
dster77 is offline
Reply Camcorders
