Canon Vixia HF R400 loud! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-13-2013, 04:01 PM - Thread Starter
Robin_G's Avatar
Has anyone else had issues with video having loud ambient noise? I used a Vixia HF R11 not long ago and noticed clicking noises on it, but I had already ordered this camera. Unfortunately I ended up leaving town for more than a week so my 30-day window for returns is on me, so I need to decide quickly to keep or return.
Does anyone know of a fix?
I am uploading a sample video to YouTube and it's telling me: The video you uploaded may have audio/video sync issues.
http://youtu.be/otGoVnnVT18
I transferred and opened the video using Windows Explorer straight from the camera. Could this be the cause of my troubles?
Robin_G is offline
post #2 of 3 Old 07-13-2013, 05:07 PM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
All video cameras have a default "AGC" or Automatic Gain Control. The idea is that any sound present will be adjusted to a "medium" audible setting. Loud things are damped and weak sounds are amplified.
Try sitting somewhere where there is a normal amount of noise. At least count with a normal voice level.
Or, find a way to turn it off and use manual loudness controls.
bsprague is offline
post #3 of 3 Old 07-15-2013, 06:30 AM - Thread Starter
Robin_G's Avatar
Thanks. Any hints on what manual settings work best for talking head interviews?
Robin_G is offline
Reply Camcorders
